How low can I go?
rp3703
rp3703 Registered Users Posts: 129 ✭✭
How low can the voltage drop on my 24V off grid system before I should flip on a generator. Most mornings, the voltage is around 24.5V or so when I wake up and the batteries are at around 80%. As soon as the sun starts hitting the panels, the voltage  will quickly go up to 25V or so but the percentage of charge won’t start increasing till around 10-11am and be at float by around 1-2pm.
I have a 5500 watt generator that has a 30A outlet and my Victron inverter has connections for me to hook the generator to it and charge the batteries if necessary. I’m just wondering at what point I should do so.
1860 W (6) Rensola JC310M, Classic 150, 430AH@24V (8) Deka DSGC15 FLA's, Victron Phoenix Multi 24/2500 Inverter
Powering-20.5 CuFt. Fridge, 1 HP Submersible water pump, UV, Washing Machine, Gas Dryer, Gas Stove, Lights and Receptacles
Off Grid Cottage on lake in Northern Ontario 46˚N
  • 706jim
    706jim Solar Expert Posts: 526 ✭✭✭✭
    edited July 2019 #2
    What voltages are you using for bulk and float? You may have read my earlier thread "L16's low voltage" in this section. To properly charge my batteries I now bring them to 29.8 volts bulk and 27.6 float and they seem to be working properly.  I'm wondering if yours are undercharged like mine were. My overnight voltage now goes to 24.8 which was typically what I saw back when I ran 12 GC's.
    You are now balancing the trade off between Generator fuel and battery life.  Batteries - when they sit low for longer times, they start to sulfate.   Or you buy fuel for generator.
    Me,  I watch the weather forecast like a hawk. If there is going to be sun enough to get full by the end of the day, I wait.   If it's a week of rain coming in, i fill the fuel tanks and run the genset 2x a day for an hour or so.
  • rp3703
    The specs on my Deka/Federal DSGC15’s say Boost Voltage 7.05-7.29 and Float Voltage 6.75. I multiplied those by 4(6V*4=24V) to get 28.2-29.16V Boost and 27V Float. Our Midnite Classic is set to 28.6V Absorb/Boost and 27.5V Float.
  • mcgivor
    My experience is, when I relied on lead acid, was if the forecast was for rain, I would use the generator, invariably it would clear and render the generator charging useless. With LFP I now wait until the end of the day to boost as required, have had to do this once in 10 months after 2 days overcast, 4 Kwh in 2.5 hours, no need to worry about fully charging, just enough to grt past the the doldrums.
    edited July 2019 #6
    I don't use a generator, and also have a 24 volt system.
    Judging a battery bank's State of Charge (SOC) by the voltage is a very tenuous situation. even minor loads can effect the voltage and minimal charging as well. As Mike stated earlier, it's a trade off between battery life (maximum cycles) and cost of running the generator. I've likely shortened the life of my battery bank after having a very long period of overcast days 3 falls back (13 days with 1 hour of direct sunlight) I was bouncing around the bottom the last few days. Below 50% and as low as 20-25%.
    mcgivor said:    ...............
     if the forecast was for rain, I would use the generator, invariably it would clear and render the generator charging useless.....
    My friends call my generator the "Fog Repeller", 5 minutes after starting, the fog & clouds clear.
  • Estragon
    True dat, though I usually just bulk off the genny.  If the sun appears, I just take it as a bonus to do some absorb.  Glass half full and all that ...
  • rp3703
    So there is no too low voltage or other indicator I need to look for to determine when it’s time to turn on the generator other than the weather forecast?
  • mcgivor
    On a 24V nominal system dipping below 24V for more than a couple of days, without the prospect of good solar forecast, may be time to get a full charge cycle in, this would be where the generator helps, too many days of low input is where sulfation begins it's cancerous process.
    Lead Acid battery voltages are dependent on what you are doing (resting, charging, discharging), the rates of charging/discharging, temperature, etc... Using 24 volts as your "genset" point for a "resting" bank and 23 volts for a discharging bank (with a few minute delay to allow for starting a well pump, other heavy surge loads) is not bad.
    Here is a link that shows how Lead Acid battery voltage responds to various conditions:
    note charts are from: I believe those charts are from Home Power #36, August- September 1993. Lead-Acid Battery State of Charge vs. Voltage ©1993 Richard Perez.
    Here is a link: http://www.scubaengineer.com/documen...ing_graphs.pdf
    vtMaps
    vtMaps
