RV AC WATTS
mountainman
Registered Users Posts: 442 ✭✭
For a 15000 but rv air conditioner. What are the starting and running watts or amps?
2kw array 6 345 q cells make sky blue 60 cc
6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
More than you want to try and power with solar.
Can you get an inverter based a/c unit?They have almost no surge, and usual run at a much lower continuous current when operating vs the high/off cycling current of a standard compressor.Overall, it is still a lot of energy from an RV based solar system.BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
Im thinking of generator sizing not looking to run on solar. I have a 10000 btu window unit that runs on a open frame 2000 gen. But I would like to no if a 3500 surge 2500 running would work for the rv ac?2kw array 6 345 q cells make sky blue 60 cc
18 amp accusense charger. 3650 champion -
I run my travel trailer, including air conditioner, on a Honda EU3000i with no problem.
I hear good reports from Champion 2800 owners running their RV air conditioning. -
Champion inverter dual fuel here (https://www.championpowerequipment.com/product/100263-3400-watt-dual-fuel-inverter/) and it runs my 15000BTU rooftop just fine. If I need to charge the batteries with my PD4060 the first bit of bulk charging will pull a good 1000w of power (AC not DC) from the genset, but I have enough headroom from the generator for both simultaneous if needed. IIRC I have seen 1800w being pulled by the A/C by itself when it was working hard.
- 230 Forum & Website
