RV AC WATTS
For a 15000 but rv air conditioner. What are the starting and running watts or amps?
2kw array 6 345 q cells  make sky blue 60 cc
 6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,186 ✭✭✭✭✭
    More than you want to try and power with solar.
    Can you get an inverter based a/c unit?
    They have almost no surge, and usual run at a much lower continuous current when operating vs the high/off cycling current of a standard compressor.
    Overall, it is still a lot of energy from an RV based solar system.
    Bill
  • mountainman
    mountainman Registered Users Posts: 442 ✭✭
    Im thinking of generator sizing not looking to run  on solar. I have a 10000 btu window unit that runs on a open frame 2000 gen. But I would like to no if a 3500 surge 2500 running would work for the rv ac?
  • PNW_Steve
    PNW_Steve Registered Users Posts: 79 ✭✭
    I run my travel trailer, including  air conditioner,  on a Honda EU3000i with no problem.
    I hear good reports from Champion 2800 owners running their RV air conditioning.
  • rbreding
    rbreding Registered Users Posts: 1
    Champion inverter dual fuel here (https://www.championpowerequipment.com/product/100263-3400-watt-dual-fuel-inverter/) and it runs my 15000BTU rooftop just fine.  If I need to charge the batteries with my PD4060 the first bit of bulk charging will pull a good 1000w of power (AC not DC) from the genset, but I have enough headroom from the generator for both simultaneous if needed.  IIRC I have seen 1800w being pulled by the A/C by itself when it was working hard.
