Schneider Combox Anomalies
mcgivor
Got my Combox up and running, albeit with a few problems which were overcome, one thing soon became obvious was when there is no PV input the real time graphic shows energy going into the battery in direct proportion to what the inverter itself uses ~33W, this is with no loads on the inverter itself, just running, loads are supported by a separate system via an auto transfer switch. This is reflected in the logs overnight as a charging source, not a big deal in the big picture but seems strange.
The second is rather a question than an anomaly, what is the purpose of the Combox dry contact? I was hoping it would be possible to program it to be useful in control, voltage, current, PV input and so forth, but the manual is pretty vague and software shows no such options, that I can see at least.
Any insight?
    reading the  appendixs of the gear manuals (not the combox manual) will give you the various functions and adjustments for them, then you have to find the sections of the combox that control those functions.
  • mcgivor
    @mike95490 Thanks for the suggestion, I've scoured the manuals and found nothing relating to inverter self consumption being transposed as a charging value. My suspicion is that a battery monitor would more accurately reflect what is actually happening, without information of sensors even the most accurate device will give eronious results.
    Dave Angelini Solar Expert Posts: 7,127 ✭✭✭✭✭✭
    I have never tried the Calibration on a CSW and do not really know if it is there for this. A XW definitely has calibration of power and many other variables. I just did one last week.
