PV OVER VOLTAGE
Hello all. I have Renogy Pwm charge controller and its been fine until now.
The pv light started flashing fast and manual says it means pv is over voltage. Never had that happen before. I removed the wire going in the cc fom the panels and my battery read 12.9v
Panels are 5x 15.9Vmp 3Amp plus 1x 17Vmp 5.9Amp all in paralelle. What I dont understand is that the sky is heavily covered by clouds like its about to rain or snow.... i shouldnt be at max power specs.
Can anyone help me ? Im afraid to plug it back in
Just plugged it back and it reads 13.1v like i would expect in a day like this.
Any clues what happened ?
_____________________________________________[3p3s 48w 15.9Vmp] [Flooded 2x 6v 150ah][Victron 50/100 700wMax MPPT] -
What is the max voltage (Voc) spec for the controller?
A cool/cold cloudy day with a breeze, and very early in the morning can actually be when the pv voltage is highest. The controller may not be "awake" to actively charge batteries, but with little sun to warm the panels, they stay cold. Panel voltage drops when hot, rises when colder. It takes very little light to get voltage, but with little/no current flow.
With a pwm controller, the battery would pull pv voltage down when operating, but it may be "sleeping" with not enough light for charging. With a zero duty cycle, the battery may not be pulling pv voltage down, leading to the overvoltage.
The controller may have a setting for a "soft" overvoltage to set a warning and/or shutdown which is lower than the "hard" overvoltage (at which permanent damage may occur). If so, and depending on how much room you have between the hard and soft overvoltage values, you may be able to nudge the soft warning voltage setting up a bit. You want to be careful doing this though, as hitting the hard limit will likely void warranty and may damage the controller.
What is the "Max. PV Input Voltage" for your controller? If it's 26V, then extreme cold might be the issue. If it's the 50V model, then maybe lightning.
High Voltage Disconnect: 16V
Over-Voltage Reconnect: 15V
Max. PV Input Voltage: 25 VDC
Here you go. Also about extreme cold. It is spring now. Extreme cold days are long gone and never had it happen during. So not that either. Wasnt lighthening storm either.
This was past noon. So not the morning thing.
If there were no changes to the system for a week or 2 prior to this, I'd figure I was just a glitch and move on... maybe look around to replace the charge controller if it fails. If it was a MPPT type controller, I might suspect the fan failed and it saying over voltage is actually it's inability to dissipate heat.
Have there been any brief sunny breaks in the clouded sky, if so the cold panels suddenly hit by full sun could spike the voltage high enough to cause the controller to go into fault.
This number could be reached in any weather. It isn't a good match for a 17+V panel.
@mcgivor probably what happens... makes total sense. Thanks
- 234 Forum & Website
