Fried Diode
Ramdriver
Registered Users Posts: 3 ✭
Do I have to repair/bypass or can I eliminate the diode in a single panel system? I fried it ☺️ Just trying to charge my battery
What diode? In the solar panel? It a charge controller?
There is what I believe is a diode soldered into the + and - terminations on the back of the solar panel.
They are diodes, used to bypass shaded cell strings within the module, this allow partial output rather than no output. They are very cheap, I would replace them, the panel will operate with them bypassed as long as there is never any shading.https://www.electronics-tutorials.ws/diode/bypass-diodes.html1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Thanks that is exactly what I was looking for!
- 230 Forum & Website
