EU2000 Honda generator troubleshooting
124»
  • RedFrog
    RedFrog Registered Users Posts: 2
    This happens without any load!
  • Estragon
    Make sure the eco mode is off when starting - that can cause problems sometimes.
  • Estragon
    Failing that, it might be worth having a look inside to see if there are any loose wires, maybe a short ahead of the circuit breaker?
    Try using the generator in plain mode, not eco mode ?    What is the load you are trying to power ?
    Dave Angelini Solar Expert Posts: 7,103 ✭✭✭✭✭✭
    Probably the oil level is too low?
    BB. Super Moderators, Administrators Posts: 33,734 admin
    I think I remember that somebody had an oil sensor fail too...
    edited June 2018 #98
    My sense is also that it is related to the ECO mode. Do you turn to  ECO OFF  for  a minute or more before shutting the machine OFF?....  HONDA recommends it in the manual...It helps to 'flush' out the fuel channels
  • cow_rancher
    cow_rancher Solar Expert Posts: 117 ✭✭✭✭
    Oil sensors do fail, I had a combination 4KW Gen and Lincoln Welder that I trouble shot for many months, even replaced the carburetor, turned out to be the oil sensor, it had plenty of oil, and in doing searches it turns out that is a common failure for that engine (B&S).
    Rancher
  • DanS26
    DanS26 Solar Expert Posts: 274 ✭✭✭
    DanS26 said:
    I wonder how many thousands of these Japanese designed engines are in the landfills right now because of these hidden fuel filters.
    I don't blame the engineering involved with these small Japanese designed engines......I blame the ethanol mandate.
    DO NOT USE gasoline with ethanol added in whatever amount in your small engines.
    If your engine cannot maintain proper RPM or surges then it could cause the problems your seeing.
    23.16kW Kyocera panels; 2 Fronius 7.5kW inverters; Nyle hot water; Steffes ETS; Great Lakes RO; Generac 10kW w/ATS, TED Pro & Emporia System monitoring since 2011
  • genkiller
    genkiller Registered Users Posts: 5 ✭✭
    Loved the EU 2000 until the newest Thai built gen I bought.
    Let us skip the obvious carb/jet fuel issues. Seems this is a problem for most that don’t care or pay attention.
    i have owned my eldest Japan built for 15 years. Absolutely no real issues with well over 3000 hours on it.
    My current generator dies after 5-10 minutes. It runs smooth, and absolutely wonderful until then
    i have ruled out the low oil switch, I have an open circuit before and directly after. Don’t even question the fuel cap!
    The generator has a small load on when it dies.
    Generator will not start again till cold.
    starts absolutely beautiful too. But dies once warm or reaches 5-10 minutes.
    What the hell am I missing? No overload light, no low oil lite. Ponder on this one!
  • DanS26
    Have you removed the in line fuel filter?  See post #74 on how to do this.
    The symptoms you have mentioned....starts fine but then after about 5 minutes it starts to surge and finally dies can be caused by a partially blocked in line fuel filter.
  • genkiller
    edited December 2018 #103
    Ruled out all fuel issues, in-line filter clean, This is strictly any slightest load draw on generator. Without load on generator, runs indefinitely.
  • DanS26
    I had the exact same issue...engine would run indefinitely without load...then die upon load.  Remove the in line filter even if it appears clean.
    Fuel pump failure or leaking pressure hose to pump (uses crankcase pressure to run pump?)?
    https://www.amazon.com/Honda-GENUINE-EB2000-Engines-ASSEMBLY/dp/B008RRFTHW
  • jonr
    When it won't start, does it have spark?   Will it start (briefly) with starting fluid?
    Up here in Canada they advertise that Honda now has "Cold Climate Technology"  Is yours one of these?  It has something to do with preventing a build up of ice in the air intake tubing...??
    Cold Climate Technology. Available on all models, Honda Cold Climate Technology™ is specifically designed for cold Canadian climates. The exclusive breather heater system helps prevent generator shutdown in freezing conditions, so you don't get left out in the cold.
  • Estragon
    Mine runs fine in the cold once it starts, but doesn't start in the cold.  If it's much under freezing, choked or not, it won't even sputter.
  • genkiller
    So an update on 2 different subjects.
    1rst: won’t run under load for more than 5 minutes.
    I thought it to be an electrical fault causing the shut down. After repetitive attaching a spark checker, I found it would only run and stay running while it was attached. Found that the dust cover on the ignition lead was keeping it from full contact or intermittent. I removed the dust cover.
    2nd. The obvious surge issue many people are having.
    Yes, a dirty carb and subsequent fuel issues can cause this.
    However, I have multiple eu2000, some made in Japan, and some in Thailand. . I have found, that all my old carb stuff do not surge in the slightest , while the new ones from Thailand do. There is no excuse for multiple new ones to surge right off the shelf. In any combination, new carb on 15 year old gen surges, old card on new gen does not.
    This is a manufacturing problem.
  • mcgivor
    edited December 2018 #110
    The fuel requirements may be an issue as the content of ethanol in Thailand is 20% or possibly higher, whereas it's commonly10% in many  countries /states. A friend here in Thailand recently aquired an EU 2000i due to frequent power outages, it runs without problems, possibly  fuel metering is different to compensate for higher ethanol content, the ones exported from Thailand may be equipped to comply with local fuel, thus not with destination fuel, just a thought.
  • genkiller
    That is a thought for sure. I see hundreds of people commenting about surge and having to run with choke on half. My new carbs from Thailand do just that. My sons generator did the same, he went with a larger jet. ( believe there are 2 only offered) but still it surges. I’m going to go a bit further and question Honda directly. Unfortunately because of the recent issues ( having no problems in 15 or more years with Japan mfr. ) I probably will never buy another eu2000. Sad! May do the jump to the 3000. But scared to.
  • genkiller
    After further thought on fuel. My son uses only race fuel in his. So I’m having doubts on the ethanol thought.
    I know this sounds simplistic, but have you re & re all GROUNDing points on that unit...  A  couple of mechanic friends have said to me when inquiring about a problem on one of my older vehicles..."Did you verify all grounding points?  when it is intermittent you have to start there.!."  Most of the times they were right and it was 'right there!'..... good hunting
  • jonr
    edited December 2018 #114
    Manufacturers tend to adjust for very lean to reduce emissions.  If a little choke fixes it, then so will the right jet replacement (assuming it's not a cleaning problem).
    My understanding is that if you use pure gasoline, it will run 3-5% richer than a E15 blend.
