Is NAWS Store web site down?
Photowhit
Solar Expert Posts: 6,023 ✭✭✭✭✭
I went to the web site to create a link for something last week and the Store web site was down. I just went there and it appears to still be down. Has there been problems?
I like sending people there.
Works fine for me.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Odd, I'm fine getting to the forum, but the store link here and from the Black Friday both give the familiar;
Wonder what is going on? I remember something odd years ago about not being able to access PayPal due to some reporting it as unsafe...
It is working for me... I know that they have been updating the site software--Perhaps they were doing some major work this morning.
I asked Rick who runs the website for NAWS... And he said he will keep an eye on it.
Store worked for me just nowPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Still not for me, might be an erroneous report locally... I'm even on a different node now about 25 miles away.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
With shared servers, one IP address can map to many actual websites... Need "real" URL to work (as I understand hosted websites).tAs far as I heard, NAWS is not seeing any issues...-BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
Found out my registration was defunct. Had to register again...??? but it is workig.
