Honda Generator
Easton
Easton Registered Users Posts: 1
Honda EU6500is invertor runs great but governor doesn’t .Was told the governor on carb is controlled by invertor .No increase RPMs under load. Any ideas?
  • mcnutt13579
    mcnutt13579 Registered Users Posts: 112 ✭✭✭
    It could be the little motor that drives the throttle shaft esp. if it has lots of hours but troubleshooting these is just throwing parts at it, $$$$$
  • Vic
    If you can get to the connectors on that throttle control motor,   you might trying to remove and reseat it/them.   Also inspect the wires to that motor. There could be some abrasion,   or Rodent nibbles on the cable.
    Just guessing,   good luck,   Vic
    edited November 2018 #4
    Does that model have a ECO switch ? Have you been able to get the unit to stall by overloading it?
    ADD:
    When was the last time you serviced/replaced the tiny in-line filter?
    See the Owners Manual for location...
    Dave Angelini Solar Expert Posts: 7,085 ✭✭✭✭✭✭
    Yea there is an ECO on it. same symptoms???  I am going to guess that the OP runs gasoline?
    We mod these great gensets for propane use. Zero problems until the engine wears out.
    Lot's of good suggestions :)
  • Porschephanatic
    Porschephanatic Registered Users Posts: 62 ✭✭
    Vic said:
      " or Rodent nibbles on the cable."
    That happened to one of mine.
  • Porschephanatic
    Why do mice enjoy chewing 25 yr old wire insulation?  :s
  • Ralph Day
    Ralph Day Solar Expert Posts: 1,038 ✭✭✭✭
    Had mice chew through an ignition coil wire on a Honda pump.  Gotten into my Honda push mower.  Now all power equipment stored has a 1x2 framed box withg 1/4 inch mesh stapled to it.  No varmints can get in.  Pump, mower, generator.  Of course, the push mower needs the handle collapsed to fit in the box.  The only thing safe is the Husky chainsaw...no places large enough to crawl in, and not the cavity spaces for nesting sites.
    Ralph
  • jonr
    edited November 2018 #9
    If you can get a volt meter (or oscilloscope) on the throttle terminals, you should see something when you switch between Eco and non Eco mode.   But it might well be a stepper motor, so it might be brief.    This would indicate if it's an upstream signal problem or a throttle/governor problem.
