Why does UAV be safety enough for Solar Panel Farms inspection?
kimixiong522
Registered Users, Users Awaiting Email Confirmation Posts: 15 ✭✭
1.Precision GPS positioning
2.One-button automatic inspection
3. Flying back automatically once losing signal or lack of power
4.Hovering automatically and stability
5.Exit task casually,one button return to home
KiMiXiong,
You need to actually engage in conversations here... Not just a bullet list for your company's drones...
-Bill "moderator" B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Tell me how it flies back with lack of power ?kimixiong522 said:
3. Flying back automatically once losing signal or lack of powerPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
3. Flying back automatically once losing signal or lack of powerHi mike95490:
It is not completely powerless, it will set a low battery reminder to the drone. When the power value is lower than the set value, the unmanned machine will automatically return.
If you want to know more, you can contact me
email : kimixiong522@gmail.com -
Useless tidbit of the day - I have a patent on a method of doing just that. Turns out that if you lose power at a high enough altitude, you can retain control of the drone by allowing the props to freewheel, then braking them selectively to maintain attitude control. That also gives you a little bit of control over trajectory, so you can select a safe area to head towards (i.e. a tree rather than a crowd of people.) That act of braking also returns power to the battery (it's effectively regen braking) and that gives you a small amount of energy back to the battery. Depending on altitude, that can be enough to go to normal flight mode for a few seconds before impact (or landing, if you want to be optimistic.)mike95490 said:
3. Flying back automatically once losing signal or lack of power -
Similar to Autorotation in a helicopter to soften the impact of hitting the ground after losing power.
