Why does UAV be safety enough for Solar Panel Farms inspection?
kimixiong522
kimixiong522 Registered Users, Users Awaiting Email Confirmation Posts: 15 ✭✭
1.Precision GPS positioning
2.
One-button automatic inspection
3.
 Flying back automatically once losing signal or lack of power
4.Hovering automatically and stability
5.
Exit task casually,one button return to home
    KiMiXiong,
    You need to actually engage in conversations here... Not just a bullet list for your company's drones...
    -Bill "moderator" B.
    3. Flying back automatically once losing signal or lack of power
    Tell me how it flies back with lack of power ?
  • kimixiong522
    BB. said:
    KiMiXiong,
    hello BB.
    Thank you for your advice.
    I am
    here not to advertise, I just want to share some useful things for everyone.
  • kimixiong522
    Hi mike95490:
    It is not completely powerless, it will set a low battery reminder to the drone. When the power value is lower than the set value, the unmanned machine will automatically return.
    If you want to know more, you can contact me
    email : kimixiong522@gmail.com
  • bill von novak
    Useless tidbit of the day - I have a patent on a method of doing just that.  Turns out that if you lose power at a high enough altitude, you can retain control of the drone by allowing the props to freewheel, then braking them selectively to maintain attitude control.  That also gives you a little bit of control over trajectory, so you can select a safe area to head towards (i.e. a tree rather than a crowd of people.)  That act of braking also returns power to the battery (it's effectively regen braking) and that gives you a small amount of energy back to the battery.  Depending on altitude, that can be enough to go to normal flight mode for a few seconds before impact (or landing, if you want to be optimistic.)
  • littleharbor2
    Similar to Autorotation in a helicopter to soften the impact of hitting the ground after losing power.
