The world is watching California open the way for the development of clean electricity
That's a mistake. Goals of 50%? 60%? 75%? Great. But getting to that 100% will be far, far harder (and far less valuable) than those other goals. Our money is better spent in other ways.kimixiong522 said:Governor Jerry Brown signed a bill that puts California on an ambitious path: --Using 100% clean electricity by 2045. The measure also speeds up the renewable target already in place to 50% by 2025 and 60% by 2030. -
Well, that will be ~25 years after he is out of office (Gov Brown is termed out and will be "retired" in a few months).
Our last "experience" with California Laws on Utility (de)Regulation was in 2000-2001. I can imagine that this next stuff to hit the fan in 2025-2045 will be just as interesting.
Usually this will start with California buying power from other states/countries (Hydro from Canada and Washington state, etc.)... Meaning California is not sustainable... Just another wealth transfer.
Here is an idea: let the people be free to do what they want with their power instead of saddling them with another heavy-handed department of whatever with salaries higher than 90% of the people they rule over.
Way before the energy laws hit, the mandatory daily personal water consumption is going to get us. $50 gal day. No Baths. State wide it's going to save - wait for it -- less than 1% of the states total use. At the cost of new water meters to "properly record" the daily usage, and new (electronic) water appliances, to not waste a drop of precious water. And a camel's nose in everybody's tent to make sure there is no cheating.
More water would be saved if the cities and water districts fixed the leaky pipes in the infrastructure, but that does not put electronic monitoring into every household.
https://californiapolicycenter.org/permanent-water-rationing-coming-california/excerpt: But how much water would actually be saved, for $47 billion? According to the most authoritative study available on current indoor water consumption, the average Californians uses 62 gallons per day. (ref. California Water Plan Update 2013 Chapter 3, page 12, 1st paragraph “Indoor Residential.”) This means that if California’s 40 million residents got their indoor water use down to 50 gallons per day from 62 gallons per day, it would save 537 thousand acre feet per year (0.54 million acre feet). This is a minute fraction, less than 1%, of California’s total water diversions for environmental, agricultural, and urban uses.
AB 1668 is not about saving water. It’s about control. It’s about power and profit for special interests.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Our water bills in ~8 years went from ~$1.25 per 100 cuft to almost $7.00 per 100 cuft (748 gallons per 100 cuft). Running around $100 per month for ~10 cuft per month (includes about 1/2 the bill for connection fees).
Roughly, I am down to ~81 gallons per day per person (3 people in home), and that includes only a little bit of garden+potted plant watering (mown weeds are a landscaping choice?).
This state is going nuts... Either too many people or too few (politicians are going for "both" as the answer).
Infested with humans...BB. said:Either too many people or too few (politicians are going for "both" as the answer)
Again, infested with humans...mcnutt13579 said:Here is an idea: let the people be free to do what they want with their power instead of saddling them with another heavy-handed department of whatever with salaries higher than 90% of the people they rule over.
In the end, we must have politicians willing to make reasonable hard choices. In general we as individuals will make choices based on our immediate needs. Basically whatever is cheaper. Likely 80+% of the population and power companies would just burn coal...
Reasonable government officials are needed to look long term and say, well even if we insist on scrubbers, coal will create too many problems, and tax that base to make other options cheaper for the individual.
….of course I'm a fatalist, our officials don't have the will, or again the people don't have the will to elect people who can make those hard choices while we rapidly climb over the hill of 'peak oil' and other resources.
CA obviously has far more water than they need, as so much is exported (in the form of lettuce, almonds, etc.).Off-grid.
You are right but the farmers are now taking the water from the ground by drilling wells. The water that they use to get from the SF bay delta and other places is being sent into the ocean. The environmentalist are trying to save things that do not matter. They say the Delta must be saved. The Delta was actually man made and so it all is flawed logic.Estragon said:CA obviously has far more water than they need, as so much is exported (in the form of lettuce, almonds, etc.).
Meanwhile the CA central valley floor is sinking from all the new wells and this huge aquifer is being destroyed.
Up here in the Sierra life is unchanged as we get the water source before it can be drained into the ocean. We have the same number of people here as 20 years ago as there are no jobs. Mostly just blue skies and wildfires in summer. Been that way since the dawn of time."we go where power lines don't" Sierra Nevada mountain area
BB. said:Well, that will be ~25 years after he is out of office (Gov Brown is termed out and will be "retired" in a few months).
-BillGovernor Moonbeam is going offgrid. I know the guy who built his power system. He definitely has a back-up Genset
--Dave
Government is the poster boy (person?) live now, pay later... Virtually anything you look at in the US (and California) is a Pyramid/Ponzi scheme somewhere. Using every financial and legal trick there is to put the consequences as far into the future as possible (after the next election, after "they retire", etc.).
https://money.howstuffworks.com/ponzi-scheme3.htm
Why there is an election in a week (100% vote by mail in our area)--Tends to make me a little be more paranoid/depressed than usual.
The people in Sacramento would not be there if they did not know what they are doing....
Don't let it get to you, but I would also tell you not to save the good wine. Drink it tonight!"we go where power lines don't" Sierra Nevada mountain area
That's the right way to do it. Charge what it costs for water, including all those billion dollar Delta projects and repairs for parts of the state that are sinking due to overuse. If someone wants to "save the poor!" or something then make the first 10 gallons a day free and charge market prices for the rest of it. The market will quickly drive conservation.BB. said:Our water bills in ~8 years went from ~$1.25 per 100 cuft to almost $7.00 per 100 cuft (748 gallons per 100 cuft). Running around $100 per month for ~10 cuft per month (includes about 1/2 the bill for connection fees).
When I ride to work I pass half a dozen office buildings whose sprinklers are sending hundreds of gallons of water a day into storm drains. Want to stop that? Charge them for what the water is worth. Then they will suddenly decide that it's more cost effective to fix the sprinkler systems.
(Here in San Diego we have another option - recycled water, which is taken from sewage, and used for irrigation. Almost no one uses it. Price water more accurately and that would change, fast.) -
Here on Catalina Island we have two desalination plants supplying most of our potable water. Also we have a salt water system for toilets. Great idea, except the salt water goes into our sewer system and causes problems with that part of our infrastructure.
Another good idea. I'd add that recycled water would be a great replacement for salt water, and could serve as water for flushing toilets, irrigation and clothes washing. (It's actually completely safe to drink, but people have superstitions about that sort of thing.) The cost would be 2x the distribution piping.littleharbor2 said:Here on Catalina Island we have two desalination plants supplying most of our potable water. Also we have a salt water system for toilets. Great idea, except the salt water goes into our sewer system and causes problems with that part of our infrastructure.
I guess with salt water the question comes down to - is it more expensive to maintain the system and/or go to all plastic or stainless, or is it more expensive to make more fresh water?
Here in San Diego we just opened a big desalination plant that's supplying about 10% of our water. One of the nice things about this type of plant (reverse osmosis) is that it runs on pressure. So you can build a water tower to provide the pressure, then pump salt water when power is cheap (i.e. solar during the day, or at midnight when the grid is oversupplied by conventional generation.)
