Powering WiFi
Also the wifi part is 24volt and the modem I'm assuming would be 12volt
Is there a reason you can't get Satellite based internet? Hughesnet, ViaSat and others offer satellite internet.
Not sure about regular wi-fi over a 1 mile range. Depends on terrain, potential interference, etc I suppose. Personally, I'd consider DSL, or a point-to-point wireless system.
Anyway, .8a at 24v is ~20w (hopefully not .8a at 120vac). Assuming the modem would be about the same, call it roughly 50w total load. The radio (wifi) part of the load may vary with actual send/receive time, but assuming constant 50w load 24x7, that's 50x24=1200 watt-hours/day. Assuming you stay lit for one cloudy day, that's 2400wh storage. For good life, a deep cycle lead acid battery shouldn't be discharged more than 50%, so 4800wh of storage. At 12v nominal, that's 200amp-hours, so a pair of 6v golf cart batteries may be a good choice.
If possible, both devices should be powered with DC voltage converters, not an AC inverter (to avoid losses).
Assuming your location would get at least 4hrs of full sun equivalent (check pvwatts.nrel.gov for actual location) on average in poor months, and actual output ~75% of STC rated output, (eg) 600w pv x 75% x 4hrs = 1800wh. Not enough to fully charge batteries plus run loads in poor sun months, but likely enough to get there over a period of a few days. If you get longer runs of gloomy weather, you'd need to charge with a small generator, or take the batteries home to charge.
All above just for example purposes.Off-grid.
New policy, sat internet requires you have an pow-co meter, which takes off-grid installs out of the picture. Existing ones are grandfathered in. Big news in my neck of the woods where there are a fair # of off-grid sat installs.littleharbor2 said:Is there a reason you can't get Satellite based internet? Hughesnet, ViaSat and others offer satellite internet.
What about boats etc? They don't sell sat systems inet for them anymore?Off-grid.
DSL would be better than Satellite the DSL is not bad but Spectrum would be better.littleharbor2 said:Is there a reason you can't get Satellite based internet? Hughesnet, ViaSat and others offer satellite internet.
Thank you for the help. Yeah it would be a wireless point to point using Ubiquiti equipment. Have used their stuff for work it's crazy what you can do with it.Estragon said:Not sure about regular wi-fi over a 1 mile range. Depends on terrain, potential interference, etc I suppose. Personally, I'd consider DSL, or a point-to-point wireless system.
All above just for example purposes. -
What is the reason for this? One thing I can say. A properly designed off grid system is way more dependable than typical POCO power. Only time I'm without power is when I intentionally shut down. THOH the So. Cal. Edison power here at home goes down at least once a month.mike95490 said:
Sorry for the double reply. So do you think one of those 100watt panels from Amazon that are like 110 bucks would be powerful enough?Estragon said:Not sure about regular wi-fi over a 1 mile range. Depends on terrain, potential interference, etc I suppose. Personally, I'd consider DSL, or a point-to-point wireless system.
You need to nail down the load needs (actual draws including conversion/inversion losses, 24x7 or ??), and location (average insolation, tilt, any shading, etc.), but probably not.
Most likely, a 100w panel will produce ~75w in full sun at normal operating temps. Assuming it runs year-round, you'll want the design to provide reasonable charging in poorer months, which may be 3-4hrs of full sun equivalent. That might be ~300 watt-hours for the one panel. Using the guesses above, you'd want more like 6 of them, but actual load and location numbers could easily make it half (or double) that.Off-grid.
I'd size your system after you get the equipment and some accurate power measurements.
This same equipment is used with WISPs which might be available in your area.johntcantrell said:Thank you for the help. Yeah it would be a wireless point to point using Ubiquiti equipment. Have used their stuff for work it's crazy what you can do with it.
http://www.wispa.org/Directories/Find-a-WISPHome system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Do you have strong cell service? We are using one of the unlimited plans and have 20-40 up/down speeds. We are remote and have very few users on the tower nearest us. We changed over because our old cell provider's towers were overloaded and our speeds died off to dial-up speeds or less when congested. We are thrilled with the new provider? An added plus is we can take the internet with us when we travel. Don't let the sales reps at the cell phone stores talk you into their internet service unless they will give you a free trial period and will not charge a restocking fee. If using cell internet is an option, have someone with each provider come over and run a speed test on each service. I am intentionally not mentioning which service was good and bad because the results vary according to tower distance, terrain, foliage, and number of users on each tower.
- 621 Discussion Forums/Café
