Installing pole mounted brackets, but can’t find 2 inch pipe!?
solarcory
Registered Users Posts: 6 ✭✭
Ok so I bought two adjustable angle mounting brackets for my panels off EBay. These use a 2 inch inside diameter pipe. At my local hardware stores all I can find is 1.5, 1.6, 2.15 inch pipe but no 2 inch.
Can anyone recommend a easier way to find 10 ft piping to cement into the ground and mount my brackets/panels on?
Cory
Cory
Try an electrical wholesaler, ask for ridged emt, 1 1/2" outside diameter is 1.9" https://steeltubeinstitute.org/steel-conduit/types-of-steel-conduit/rigid-metal-conduit-rmc/1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Those appear to be satellite dish brackets. The tubing/pipe they use is a very thin wall material. Are you looking for 2" OUTSIDE diameter?
Mcgivor- thank you I’ll look into that.
Littleharbor2- yes, definitely looking for 2 inch OD piping. -
Home Depot has 2" Sch 40 pipe...Justin B.
Cabin - 9 Mission Solar 310 watt panels, MidNite Solar Combiner, Iron Ridge mounting, 4 Speciaized Power 200 AH 24V LiFePO4 batteries, Samlex PST-1500-24 inverter, MidNite Solar Classic 200SL CC
Barn - 9 Renogy 100W panels, Generic Chinese 40A MPPT CC, 6 Universal 12V 100 AH AGM batteries, Reliable 3KW 12V PSW inverter -
Ok!
So Ive spent a lot of time at Home Depot and Lowes looking for a 2 inch pipe and am still not having much luck.
Ive brought my bracket with me into these hardware stores and am testing it on multiple pipes, and even when ratcheting the bolts down, the bracket bottoms out on the bolts before its tightened to the pole.
Ive looked at fence poles, and found a 1-7/8 inch pipe that fits somewhat loosely but tighter than other pipes.
Ive looked at rigid electrical conduits and found a 1-1/2 inch pipe that is close to a 2 inch OD.
Ive even looked at plumbing piping and they are similar to the pipes above.
Now, the bracket I have, I quickly measured it with a measuring tape, I wonder if I have a 2.15 or 2.20 inch inch ID mount on this pole bracket. -
Im getting pretty close to just getting the closest size pipe I can find and then welding some bands where the clamp attaches to make the pipe diameter larger and then cementing the pipe in the ground.
Looks like chain link fence pipe comes in 2" OD up to 10 feet long at 40 WT. Not sure if this is strong enough.
Call to verify actual OD.
https://fence-material.com/galvanized-pipe-2-od-40-wt-chain-link-pipe-fence-pipe/
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
solarcory said:Ok!
So Ive spent a lot of time at Home Depot and Lowes looking for a 2 inch pipe and am still not having much luck.Justin B.
I used a chain link corner posts filled with concrete. I was told here that it was a bad idea. Had 45 mph sustained winds with gusts or 60 mph most of last night. The worst issue is a couple of leaves need to be removed.
Just spent $80 for 10' of 2" galvanized pipe at a large electrical distributor (CED or QED in Denver). It is very heavy duty pipe, I'd estimate the thickness at close to 3/16". Weight might be close to 45 pounds. This would be ideal pipe for a solar array. Few events would effect this pipe and it is made for outdoor duty. Minimum length was 10' at CED.
Had to replace the "electrical service line" on the roof after I successfully dropped a tree limb on it. Note when doing chainsaw work - do not underestimate the leverage of a dropping limb. Even if thin at point of impact, the limb is connected to a lot of weight traveling at a surprisingly high speed.
If one ever has to replace the electrical service lines, be of good cheer. It is about as difficult as tying shoelaces. A challenge may present in connecting the lines due to necessary tautness. Also in making 2/0 fit into tight spaces. Homeowner owns this section of the electrical service. Your utility company will be happy to tell you this.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Good stuff but not inexpensive: https://www.fastenal.com/products/details/0700025First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
FWIW, just measured the original electrical service pole and the replacement pole thickness. The original pole is .10" thick - 1/10". The new pole is ~.15" thick ~1/6.7" - 50% thicker than the original. Apparently 2" electrical conduit can vary significantly in common sizes.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
- 612 Discussion Forums/Café
- 305 In the Weeds--Member's Choice
