Need Replacement Invert Advice.
solorone
Solar Expert Posts: 257 ✭✭✭
OK, question for serious folks off grid .What is the better inverter in the 1500 to 2000 watt range with battery charging. Midnight, Magnum, Outback Xantrax . Had a customer email today, lighting got her unit. I sold and installed her a setup 25 years ago. She needs to pump water, I am sure pump is 1/2 horse. original setup was with the famous Trace DR 1500, a real work horse, then a Xantrax. Cheers
Kind of you get what you pay for . I have the outback fxr happy with it . I like the way it slowly ramps up when charging .You do however need a mate to change its many parameters, however once programmed it can have the mate removed .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
One would be inclined to answer replace with the same brand, 25 years service is impressive, but there are more players in the market with a solid reputation, brand loyalty may influence answers to some degree, the higher end units are probably all good so it would come down to features, warranty and price, I would think.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Was Schneider left out on purpose or just not available?REC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
- 234 Forum & Website
