PV water heating
                    sawmill
                    Solar Expert Posts: 93 ✭✭✭
                    I have 2- (unused) 290w panels, 39.4voc, 9.5 isc that I want to use on a17 gal preheat tank for Rennai.  Is there any advantage to wiring them in series or parallel or does it make any difference?   Also would there be any difference to what watt element is used since all available PV wattage is being converted to heat?
            What's the voltage on the water heater element?Off-grid.
            1 have been experimenting with a 120v element like used in campers. I don't know if an (cheap) ac element is more or less efficient than the ( expensive) dc ones. I suspect the element doesn't care whether it's ac or dc.
            You're correct, the element doesn't care if it's ac or dc. It's a purely resistive load.Off-grid.
 Pretty much it's a pure resistance load. It works out that half the voltage (resistance) will max out at 1/4 the power, so a 120v 1500 watt element will max out at about 375 watts at 60 volts. You would use vmp to calculate, and I suspect your panels would be close to 30 volts VMP, and likely to have a bout enough power at NOCT to run at 375 watts. Should be a good match.sawmill said:I suspect the element doesn't care whether it's ac or dc.
            @Photowhit is correct
 Here is a formula to calculate what wattage an element will be rated at for a given voltage, for interest purposes on h
 Say for example you had a 1500W element rated at 120V and you were to apply 60V to it, this is the calculation you would use to determine the wattage.1500×(60/120)squared = 375 wattsThis demonstrates why it is best to match voltage ratings, now 1000W element 24V rating using 24v1000×(24/24)squared=1000W1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
            Thanks for the insight guys. Several years ago it would have been considered a sacrilege to use pv this way but with the current price of panels it makes sense in certain situations.
 What does care, is the Thermostat. Getting a thermostat rated for high watts DC is not easy.Estragon said:You're correct, the element doesn't care if it's ac or dc. It's a purely resistive load.
            Yup. Might be easier to run it at 120vac off inverter as an opportunity load.Off-grid.
            My 3/4 mile gravity water system runs 60psi so the boiling point would be over >250F. Even if one could boil the water once 60psi was reached it would start pushing water back to the storage tank. The Rennai also has a popoff. Since these are 2 un used panels I thought this would be a good use.
 I am still unclear about PV parallel or series connections or does it make any difference?
            Thanks Estragon
 Fwiw I have been experimenting with a 10 gal rv hwh. The element voltage is 120 unknown watts. ohms are roughly 35 at 80f. With 4 100 watt panels 18.9 vmp. Connected to the element in series. Amps read 2.25 at 75.8 volts 170 watts With 2s2p 1.09 38.5 v 42 watts. All in parallel 0.63 amps and 21.1 volts.13 watts.2kw array 6 345 q cells make sky blue 60 cc
 6 230ah GC @36 volts
 18 amp accusense charger. 3650 champion
            Mountainman, your experiment sounds very similar to mine. I have filled a 17 gal barrel and set the 2 panels(series) beside it for a real world experiment. I am also located in the NC blue ridge mtns. Last several days very little solar so nothing of value yet.
            since all available PV wattage is being converted to heat?Not really. If the panel voltage is not held to the power point a LOT of POTENTIAL power is lost. A heater element will only be a good match for two hours a day. The rest of the day you will get 1/4 of the panels potential power. Is there something magical about 17 gallons or is this tank already there? A 6 gallon tank would be a batter match and probably provide hot water with out being a preheater. I have a 9 gallon tank with a power point control and that provides all my hot water at camp, even enough extra for a dishwasher if done mid day. I've been experimenting with PV water heating for years. There are designs on youtube, 99% of them have no idea of what they are doing.
            I've been doing some reading on pv water heating and it seem seems midday good sun needs lower ohms and low light early morn and afternoon requires higher ohms. 2 of the same watt elements are needed. 1 for good sun and 2 in series for low light. Panel Vmp/imp=ohms of elements needed. 2kw array 6 345 q cells make sky blue 60 cc 2kw array 6 345 q cells make sky blue 60 cc
            Results of my real world experiment-two 290w panels (series) will bring 17gal to 105f in a non isulated outside barrel. Yes Nano, the 17 gal tank is pre-existing for a Rennai on demand heater.
            I had to look back and see what the original question was. Looks like problem solved. What element are you using? With the right controller and insulated tank, that much power could supply real hot water for a house. I sure like not buying propane for that. Just for amusement, this was my prototype water heater controller I used for a year. The bubble wrap is IP-67 environment protection. Not so good for spiders.
- 232 Forum & Website
