Solar water heating
mountainman
Registered Users Posts: 439 ✭✭
I have an rv with a 10 gal lp and ac hwh. Using midday sun with 400 watts dirrectly connected, can someone tell me how long it would to take to raise the water temperature 50 degrees from 70f to 120? And what ohm or wattage element would I need?
2kw array 6 345 q cells make sky blue 60 cc
6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
You need 4170 BTU = 1222 Wh, so about 3 hours. What voltage (Vmp) are the panels? How do you intend to make sure that you don't overheat the water?
Thanks for replying @jonr. Panels are 18.9 vmp and 5.29 imp. I had planned to use a breaker to disconnect from the array after the time was up. On second thought with clouds and such I guess the time would vary. So a thermostat would be needed.2kw array 6 345 q cells make sky blue 60 cc
18 amp accusense charger. 3650 champion -
You might want something like:
https://www.solar-electric.com/diversion-load-water-heating-element-12-24-volts.html
The thermostat or whatever breaking the circuit should be DC rated.Off-grid.
Few thermostats are rated for DC useage
Around 1.4 ohms for the element resistance, depending on low light/sun hours tradeoffs. You must solve the thermostat problem .
Consider this (search ebay for Solar-Water-Heater-EZ-DIY-Save-No-Pipe-Changes-Hot-Water-System-PV-MPPT).I am available for custom hardware/firmware development
Thanks for all the useful info. With 400 watts on one array and 100 on another. Most days in summer if i adjust the panels easterly I'm getting to float by 11 or 12. So from roughly 12 to 3 my thoughts were to switch the 400 watt array from the batteries to the hot water heater. I'm not sure of what type of switching I'll use or the effect on the controller. The 100 watt array should run my small day loads and keep me in float. A 120f dc thermostat will be used.2kw array 6 345 q cells make sky blue 60 cc
Maybe the larger one would last longer.
For full midday sun shouldn't panels be parrelell? What am I doing wrong? How do you calculate ohms. This is how I'm doing it 18.9x18.9÷400 =0.893025x 1.4=1.250235 ohms.2kw array 6 345 q cells make sky blue 60 cc
You can use R = VxV/P. But use a very conservative value for P (watts) to account for cloudy days.
On cloudy days I had planned to use lp. Because I probably wouldn't get to float early enough to get 3 hrs for hwh. Sun goes behind mountain in summer around 3:30.2kw array 6 345 q cells make sky blue 60 cc
Then I agree, 1.25 ohms might be better than 1.4.
Perhaps another way of looking at it, or at least you might get some ideas, is from this site:
I checked the 120 volt hwh element that came in the rv. With my ohm meter set on 200 I get a reading of 35.3. So 120 x120 ÷35.3=407.93 watts. Am i doing this the right way?2kw array 6 345 q cells make sky blue 60 cc
mountainman said:I checked the 120 volt hwh element that came in the rv. With my ohm meter set on 200 I get a reading of 35.3. So 120 x120 ÷35.3=407.93 watts. Am i doing this the right way?
- 626 Discussion Forums/Café
