Solar water heating
I have an rv with a 10 gal lp and ac hwh. Using midday sun with 400 watts dirrectly connected, can someone tell me how long it would to take to raise the water temperature 50 degrees from 70f to 120? And what ohm or wattage element would I need?
2kw array 6 345 q cells  make sky blue 60 cc
 6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
  • jonr
    edited August 2018 #2
    You need 4170 BTU = 1222 Wh, so about 3 hours.   What voltage (Vmp) are the panels?  How do you intend to make sure that you don't overheat the water?
  • mountainman
    mountainman Registered Users Posts: 442 ✭✭
    Thanks for replying @jonr.  Panels are 18.9 vmp and 5.29 imp. I had planned to use a breaker to disconnect from the array after the time was up. On second thought with clouds and such I guess the time would vary. So a thermostat would be needed.
  • Estragon
    You might want something like:
    https://www.solar-electric.com/diversion-load-water-heating-element-12-24-volts.html
    The thermostat or whatever breaking the circuit should be DC rated.
    Few thermostats are rated for DC useage
  • MrM1
    MrM1 Registered Users Posts: 487 ✭✭✭✭
  • jonr
    edited August 2018 #7
    Around 1.4 ohms for the element resistance, depending on low light/sun hours tradeoffs.    You must solve the thermostat problem .
    Consider this (search ebay for Solar-Water-Heater-EZ-DIY-Save-No-Pipe-Changes-Hot-Water-System-PV-MPPT).
  • mountainman
    Thanks for all the useful info. With 400 watts on one array and 100 on another. Most days in summer if i adjust the panels easterly I'm getting to float by 11 or 12. So from roughly 12 to 3 my thoughts were to switch the 400 watt array from the batteries to the hot water heater. I'm not sure of what type of switching I'll use or the effect on the controller. The 100 watt array should run my small day loads and keep me in float. A 120f dc thermostat will be used.
  • mountainman
    edited August 2018 #9
    @jonr would a 24 volt 400 watt element be a good choice? If i used 48 volts at 1600 watts would it last longer or heat slower etc? By my calculator either has 1.44 ohms
  • jonr
    Maybe the larger one would last longer.
  • mountainman
    edited August 2018 #11
    For full midday sun shouldn't panels be parrelell? What am I doing wrong? How do you calculate ohms. This is how I'm doing it 18.9x18.9÷400 =0.893025x 1.4=1.250235 ohms.
  • jonr
    You can use R = VxV/P.    But use a very conservative value for P (watts) to account for cloudy days.
  • mountainman
    On cloudy days I had planned to use lp. Because I probably wouldn't get to float early enough to get 3 hrs for hwh. Sun goes behind mountain in summer around 3:30.
  • jonr
    Then I agree, 1.25 ohms might be better than 1.4.
  • MrM1
    edited August 2018 #15
    Perhaps another way of looking at it,  or at least you might get some ideas, is from this site:
  • mountainman
    I checked the 120 volt hwh element that came in the rv. With my ohm meter set on 200 I get a reading of 35.3. So 120 x120 ÷35.3=407.93 watts. Am i doing this the right way?
    Many materials will change resistance (usually increase) when they get hot.   Tungsten elements in light bulbs and toasters are like that, low resistance when cold, higher when hot.
