Maximum battery charging current
Nabiru3
Nabiru3 Registered Users Posts: 13 ✭✭
so I have 2 flooded lead acid (153Ah each) batteries (which their datasheet states that the maximum charging current is 13% of C20) both connected in series, meaning in my case I should charge the batteries with a current less than 19A. But I have solar panels producing around 27A per hour. Does this mean the solar charging will damage the battery's health ? and can/should I limit the charging current of my solar panels ?.
Arigatou everyone 😊.
    Likely not enough information.
    You have 2 batteries in a 24 volt configuration for a battery bank of 24 volts at 153 amps?
    What are your solar panels? and type of charge controller? And how are you determining the 27 amps?
    An MPPT type charge controller can often limit the amount of output.
    edited July 2018 #3
    And what is the array configuration (series/parallel connections of the panels)?
    Also, just a quick note... Amps per hour---It is just Amps.
    Amps is a "rate" already.  One coulomb of charge going past a given point per second.
    1 C =
    6.2415093×10^18 protons or electrons (or other charged particles) [fixed]
    We use Amps as the flow (like gallons per Hour) and Amps*Hours (AH) like an amount (total gallons pumped).
    Watts is similar... Watts is a rate of energy usage. Watt*Hours is the total amount of energy usage.
    In normal day to day usage around here, Amps per Hour and Watts per Hour are not used.
  • jonr
    edited July 2018 #4
    Sticking to the datasheet is the proper, safe thing to do.    While I suspect you could go a bit higher, I've also heard that faster charging requires longer absorb - so you don't get a proper full charge much faster.
    If you don't have a MPPT controller with current limiting, you might use a clamp on ammeter to see what you are actually getting (perhaps less than you think).
  • mcgivor
    edited July 2018 #5
    1 C = 6.2415093×1018 protons or electrons (or other charged particles)
    Sure a typo or something, formula should read 6.2415093 × 10 to the power 18 or 1 000 000 000 000 000 000,  6.24 quintillion
    I forgot this forum software does not handle sub/superscritps...
    1 C = 6.2415093×10^18
    Just a cut and paste from a Wiki...
  • mcgivor
    Did the copy paste with same results, hence the manual input.
