DC breakers
ws9876
Solar Expert Posts: 453 ✭✭✭
a search on the web for DC din rail breakers always brings up Midnite Solar units for 22 bucks. Is anyone else making DC breakers anywhere in the US that are cheaper..??
Midnite Solar breakers are competitively priced.
You can also look up Square D QUO breakers they have Din rail mounting and are rated for up to 48 volt systems. That being said They aren't recommended for higher voltage PV strings.
Did you check our sponsors site? They run $11 and change for new Midnite Din rail breakers, up to 90 amps I think (use to be 63). Here's a link to a 15 amp breaker,most popular for combiner boxes. Northern Arizona Wind and Sun has some of the best prices for Midnite equipment you will find anywhere!ws9876 said:a search on the web for DC din rail breakers always brings up Midnite Solar units for 22 bucks. Is anyone else making DC breakers anywhere in the US that are cheaper..??
https://www.solar-electric.com/midnite-solar-mnepv-15-amps-circuit-breaker.html
The above link was for an AC breaker here are DC offerings https://www.solar-electric.com/catalogsearch/result/?q=dc+circuit+breaker+
Thanks, I corrected it. Good catch!mcgivor said:The above link was for an AC breaker here are DC offerings https://www.solar-electric.com/catalogsearch/result/?q=dc+circuit+breaker+
