1400ft off grid well
we had a well dug and ended up with 1.25 gpm at 1400ft deep, with the static level at 100ft. We will be entirely off grid and are looking at putting in a solar powered well pump. For the first year the solar pump will just be used for irrigation and construction uses, and will run on DC current into a stock tank. Once the house is built, the pump will be run off the solar power system for the whole house so it can run even when the sun is down. We are building a small house for 2 people, with modest garden and all composting toilets. The pump that has been recommended to us is the Grundfos 6 SQF 3, which has a max depth of 820ft and max pumping capability of 5.9 gpm. We would like to pump directly to a pressure tank once the house is built, which I have been told reduces the effective depth that the pump can handle by 140 ft. Hence, we are considering putting the pump in at about 600ft deep, which would give us about 750 gallons of storage in the well above the pump. A few questions:
1) one well pump installer has said that it is a bad idea to put a pump half way down a well, as the rest of the stagnant water below the pump is likely to grow bacteria due to the lack of circulation. Is this a real concern? Our well is drilled through solid granite bedrock with occasional layers of quartz.
2) is 5gpm adequate for normal household use?
3) is 750 gallons of water storage in the well with a 1.25 gallon recharge rate and 5gpm draw adequate for normal household use?
4) we know putting in a cistern would ensure we always have adequate water, but because the well is so deep, we are hoping to simply use the storage capacity in the well. Our concern is that the recommended pump might not be adequate because of the depth limit. Can that pump be placed lower? Would it decrease the flow rate? Is there another solar pump out there with a deeper capacity?
thanks in advance!
thanks in advance!
The well supplies at 1.25gpm, and the pump sucks out at 6gpm, so obviously the water level drops when the pump runs. The question then, it seems to me, is how far down does the water column get drawn, and can the pump handle it?
Hope this helps.
Rancher
Mike95490, are you saying that even though the well pump we're looking at says it maxes out at 820ft, we could possibly put it down lower anyway? Would that decrease the flow rate coming out to the house?
Just for some clarification, the SQF pump has an autostop mechanism in case of running dry, so it is not supposed to get damaged if it does run dry. The major water flow is coming in at about 1300 ft deep.
You can also install a metal roof and capture rain for insurance.
Offgrid is all about being redundant in all of the basic requirements if you are going to live there full time.
http://members.sti.net/offgridsolar/
E-mail [email protected]
For the OP here, an SQF will sense all the bad things listed and shut down long before any damage. You do have to have the electronics section working to sense flow. The Franklin and other old tech pumps can be protected also as mentioned.
How do I determine what the pumping level (or drawdown) will be before putting the pump in? I'm assuming this requires a calculation of how many gpm is being pumped out, the volume of water in the well, and the flow rate, right? Anyone have a handy formula I could use?
FYI, I will use a professional well company, but so far the 3 companies I've spoken to have all given me different information and recommendations, so I'm trying to educate myself enough to understand the differences between what they are saying. So far, this forum has been most educational!!
Bill
In my area they test the water depth , then pump for 4 hrs and see how low the water drops.
Then see how long it takes to refill .
A easy test, my well is 800’ 3/4 gpm and I’m looking at the SQF pump.
My water level in September is 300’ down the rest of the year I have more water .
I plan on placing my pump @590’ @ 600 feet or more my well guy is suggesting I use galvanized steel pipe .
I will pump to a large tank with 5 solar panels and use a small pump to supply the house .
http://www.groundwatersoftware.com/calculator_7_time_drawdown.htm
The method I use as a safeguard is a float switch, which prevents running below a certain level, perhaps this would be a useful means in your case, always keeping a certain amount above the pump. The recharge of 1.25 gpm is not much, additionally that figure may change over the course of a year, unknowns are hard to plan for. The deeper the pump is placed the greater the energy required, as the static level drops being off grid this is an important consideration. Pumping for short periods like 10 minutes on 20 off for example would allows the well to refresh, so a smaller pump at a shallower depth could be employed..........just a couple of random thoughts
Rancher
But he does this every day .
The pump guys are separate here , usually they come with a pump truck with the boom and they have pumpsOn a big trailer to check the flow rate and all that or if the flow is very slow.
They bring in a hydraulic fracturing to Crack the rock ,
They also have pump Equipment because after Fracking the well, they pump it to open up the veins in the rock .
I have a lake house 800’ from a 32 mile long lake and my well was bone dry for 1100’ then I had a gusher , drilled to 1200 feet , I can see the water in the hole.
The pump is set at 300’ you never know but the water is sulfur
Funny you should mention that, I used my well water for irrigation, some plants turned brown and died. Turns out the water is saline,, had to resort to pumping from rain water collection ponds consisting of 32 000 000 liters or 8 500 000 gallons, should have tested the water first I guess.
There are so many bad well stories I hear of with my clients and friends that stem from the drought out west.
The farmers are PO'd about the water going to the ocean and Socal and they drilling everywhere for irrigation in the valley that feeds the alot of country and even the world. It is sinking down there and these aquifers collapse and probably will never get their capacity back.
Thanks to everyone for the recommendations on water harvesting. We will be doing some, but I live in Colorado, which means we're technically only allowed (2) 50 gallon drums to collect rain water in, and it's only permitted for irrigation. Silly, I know. But also, that's *technically speaking*... That said, we are also required to have a 2400 gallon fire cistern, which we're *technically* not supposed to ever touch, but we'll have that on the property, so if there's ever a time that the well pump isn't working, we will have access to some water.
Anybody know about issues with bacteria growing in the water below the level of the pump because of a lack of circulation? The well is drilled through solid granite with occasional quartz veins. Only one of the 3 pump specialists I've spoken to have brought that up as an issue, but it's pretty critical factor, as we'd be talking about the difference between putting the pump at about 600ft vs 1300ft. Those pipe and electrical costs add up quick!
Rancher
I think the SQF pump controler only works to 600 feet max .
Standard well pipe is rated at 300 for Polly and 500 ‘ +- for solid pvc sch 80 I think .
I would go 590’ and give it a try .
If you run out of water in the dry months you could allways add a storage tank and pump slow to match your Recovery
rate .
It also may not really matter if the pump can max rpm if the well draws down too fast....
I like the saying about all the ways well water bad and how very few ways that rainwater can
Grundfos (SQF) says a max of 500' below static level*, but I'd be conservative and put the 6-SQF-3 at 500' below the ground level. Don't worry about additional storage for normal household use (but irrigation would change things).
Be sure to use pipe that can handle ~250 psi (or set the pump even shallower than 500' below ground).
* - "Maximum: 150 m below the static water table (15 bar)". Page 35, http://net.grundfos.com/Appl/WebCAPS/Grundfosliterature-1569.pdf
My experience is not from searching the web but actually doing the work of making it perform. Here is the curve I used.
