Chinese Li-ion batteries for RV
Shadowcatcher
Solar Expert Posts: 228 ✭✭✭
Some one on the Teardrop &Tiny Travel Trailer forum asked if any one had experience with Chinese Li-ion batteries. Smaller less weight... The question is this https://dmdinverter.en.alibaba.com/product/60536302549-804800430/Deep_cycles_2000_times_ultra_light_ultra_thin_12v_lithium_panel_energy_storage_solar_battery_200ah.html?spm=a2700.8304367.0.0.bJQ9DU A real life possibility and what are the down sides.
Shadowcatcher said:Some one on the Teardrop &Tiny Travel Trailer forum asked if any one had experience with Chinese Li-ion batteries. Smaller less weight... The question is this https://dmdinverter.en.alibaba.com/product/60536302549-804800430/Deep_cycles_2000_times_ultra_light_ultra_thin_12v_lithium_panel_energy_storage_solar_battery_200ah.html?spm=a2700.8304367.0.0.bJQ9DU A real life possibility and what are the down sides.Warranty claims ?Which "Li" formula ? LiPo4 (LFP) seems to be the safest (least fire) pack compared to others. But still burns well..getting mismatched batteries that reduce your expected pack capacity by 20% ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
NO !!pic from your link These are possibly "re-claimed", re-wrapped batteries from failed laptops(and I don't trust their -20C temp spec) (I don't trust the different shades of heat shrink wrap)Way too many contact points - just 1 bad one can ruin your dayhttp://laserpointerforums.com/f67/fake-ultrafire-18650-s-72833.html
https://batterybro.com/blogs/18650-wholesale-battery-reviews/104619270-can-you-identify-the-fake-lg-hg2-18650-battery
There are other Chinese manufacturers, thanks for the potential problem.
Shadowcatcher said:There are other Chinese manufacturers, thanks for the potential problem.
Having said that, I'm only a very interested observer of all the Li Ion battery technology. However there are several *REAL* experts here and you should probably pay some attention to them.Off-grid cabin: 6 x Canadian Solar CSK-280M PV panels, Schneider XW-MPPT60-150 Charge Controller, Schneider CSW4024 Inverter/Charger, Schneider SCP, 8S (25.6V), 230Ah Eve LiFePO4 battery in a custom insulated and heated case. -
@Shadowcatcher
There are a lot of RV's that use Lithium Iron Phosphate (LFP) batteries. There are basically 2 types. There are manufactured 12 volt packs, usually 100 amp hour, but they can be installed in parallel for more amp hours.
https://www.solar-electric.com/battle-born-bb10012-100ah-12v-lithium-battery.html
Then there are the large prismatic LFP cells that range from 20AH up to 1000AH. These cells can be purchased in custom built packs with a BMS or they can be top balanced and installed as a DIY battery bank. Proper balancing and charging procedures need to be carefully followed with a DIY bank.
Here's a link to this type cell.
http://www.electriccarpartscompany.com/Prismatic-Lithium-Batteries_c_1.html
Rick
4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Most of the serious guys in the past eschew the use of "drop-in" replacements, and go for KISS with large prismatics. But to each his own. Note that some manufacturers may warn against doing any sort of series-parallel arrangements. Mostly because trying to keep disparate drop-in cells balanced amongst themselves can be an issue.
Sadly, with LFP, the basics of battery bank construction are lost.
Ask yourself this: If you were building a large capacity AGM bank for your RV, would you purchase hundreds of 2.5Ah Odyssey/Enersys Cyclon cells and tack weld them all together and slap them in a box? (as good as those are). NO.
At least battle born identifies the LFP chemistry. However, we have no idea what the quality of those internal cells are, nor are we assured that the quality won't change if they decide to go with different vendors. The consumer won't know. Essentially, you don't know what you are getting.
Do you buy lead acid this way not knowing who actually made your cells?
In the past, *NEW* cells like A123 were proudly identified as being the internal cells with certain large(ish) capacity batteries (along with Kokam and others), for those of us in the know to make a more informed decision.
STill, at some point we avoid the "magic box" concept not knowing what is actually inside, and potential problem points adding up from so many internal connection points. Hence the simplicity of large prismatics you can actually put your voltmeter across - on each and every cell as part of a preventative maintenance routine.
The prismatic looks interesting, the Morningstar solar controller can be programmed to work well and Progressive Dynamics makes a head unit for their converter. Thanks all for your input.
Raj174 said:@Shadowcatcher
Rick
@OldMan
Yep, I have spoken with Carl several times and yes, he knows his stuff. So, 8 100AH cells in series is a 24 volt 100AH battery bank. Standard charge current is about 33 amps. The 3 panels with an MPPT controller should give you 21 to 26 amps depending on panel temp. It's a fairly small bank for a 3000 watt inverter, but you haven't stated the loads involved so might be ok. What's the brand and model number? Is this for RV?
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Raj174 said:@OldMan
Rick
Inverter brand is Power Tech on (Arizona company), This is the inverter.
Charge Controller is an EPPV Tracer 40a MPPT. This is the controller.
I hope I'm doing this right. I am less confident today.
OldMan said:Raj174 said:@OldMan
Rick
2 parallel strings of 4 cells in series would give you a 12 volt 200AH bank.
If I were going to set up a 12V 400AH bank I'd use four 400AH cells. Easier to balance, easier to manage. But I do not like paralleling strings. Carl would probably disagree with that, but that is my preference.4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset.
@OldMan
The inverter link didn't work. I assure you that 16 100AH cells would be necessary to make a 12 volt 400AH bank, but I wouldn't recommend doing it that way. There must have been some miscommunication with Carl concerning the battery. They had 400AH cells up until a couple of months ago but not now. 220AH are the largest they have right now.
@OldMan
Also, the 40 amp controller is going to limit power production to 576 watts or about 2.5 KWH, and that's with a 5 hour solar day. Probably less than your loads and about half of what a 400AH bank will hold. I believe a 60 amp controller would be more appropriate.
Raj174 said:@OldMan
RickRaj174 said:@OldMan
Rick
@OldMan
The reason I asked about the inverter is the tare lose, the power that the inverter itself uses. It can be 500 watt hours or more per day with larger inverters and needs to be taken into account with the loads while planing a system.
Raj174 said:@OldMan
Rick
@OldMan
I'm not sure about a rule. The tare lose is in watts, and usually listed in the inverter manual.
By the way, did you get the battery issue resolved with Carl?
Just to clarify, there are two types of inverter losses.
There's a loss inherent in the efficiency of converting lower DC voltage to higher AC voltage, which depends on the inverter and the size of load. Peak efficiency seems to be about 85% for most decent PSW inverters, but it can be much lower with small loads on a large inverter.
There's also a loss caused by just having the inverter on and idle. Larger inverters tend to have larger idle losses. Some have a search mode to reduce this type of loss.
Raj174 said:@OldMan
Rick
Are you going to buy the fortune 100 ah cells? I did do 16 cells for a 24v setup so far it's been about 40 days and going good. Purchased from carl also.200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
Hi....you can call them all lithium ion in the event that you need. That isn't the thing they are as per individuals who make them. Wikipedia is only a social affair of assessments, prattle and realities, arranged to the most awesome aspect of their capacity. Be that as it may, for this string , and battery perils the lifepo4s don't in any capacity represent the dangers of the lithium particle or lithium polymers, the other two most basic lithiums. With respect to wording, we'll simply need to differ and leave it at that.
- 228 Forum & Website
- 618 Discussion Forums/Café
