Phantom Loads - Oh my!
When shopping for stuff, it's really difficult to find info on phantom loads for things like digital countdown timers for code required ventilation fans (a watt for the "Off" LED? maybe better to just find an old fashioned wind-up fan timer somehow), digital multi-location dimmers (? Watts), and things required by code like arc fault breakers ( a few Watts each) , 120 VAC hard wired smoke detectors (? Watts). Seems like no-one really wants us to know about these phantom loads.
We thought about using occupancy sensor light switches to save power but it seems that they draw several watts and would be a net loss compared to being frugal with turning off lights manually. We were looking at the neat Lutron Maestro digital dimmers that allow using master slave ("companion") dimmers to dim lights from several locations on one circuit - but no info available if these dimmers have a phantom always on draw, which I suspect powers their "digitalness" via the neutral wire that these require. Apparently some types of LED capable dimmers don't try to leak current through the LED's to power their internals when on as they don't get enough power this way so they are going to a separate supply via the neutral wire. Guess I'm going to have to call Lutron to see what the "off" loads are.
Has anybody got measured on any of this kind of stuff?
These types of loads are always connected loads even when stuff is "off" so they can really add up when living off of a battery.
Speaking of "phantom loads required by code" I had an electrician actually tell me that even though we were off grid, if we installed our 120/240 VAC distribution panel in an "unconditioned space", we would actually have to install electrical baseboard heat below it .....
Offgrid in cloudy PNW
Full Schneider system with 18 REC 420W panels, 100A-600V controller, XWPro, Insight Home, six Discover AES Rackmount 5kW batteries, Slimline enclosure, Lynk II, AGS, H650, H2200, H3000 (Propane conversion on Victron AutoTrans with Gen Line 2 wire AGS on AC1), Kubota 4500, Onan 7500 (on second AGS and AC2).
Welcome to the nanny state. I was forced to install all the above, and fire sprinklers in an unheated garage. Duh! 25F tonight, and 21F tomorrow night - do I leave one on all night ?Wait till the battery backed up, hard wired smoke alarms start to fail. I had 5 or 6 go out in first 6 months.I assume all the mandatory loads are 5w each, easier than the research to find they are 3.7w new models that don't ship till next yearEnjoyPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks Mike
Folks on Lutron forum got back to me: Maestro dimmers draw 0.6 W ea when off. Lumea and Contour draw 0.0 W (mechanical off switch so no phantom loads)
Cheers
Love to know the reasoning behind this?Graham Parkinson said:Speaking of "phantom loads required by code" I had an electrician actually tell me that even though we were off grid, if we installed our 120/240 VAC distribution panel in an "unconditioned space", we would actually have to install electrical baseboard heat below it .....
All my Mains have been outside in in conditioned space for 12 years. I worked in a camping community where all the mains were at the pole, I didn't notice any baseboard heaters under them...lol.
Pretty sure that "soyboy" is full of it. Electricity is one thing that seems to work regardless of the temperature. Though I seem to recall high temperatures reducing the conductivity of aluminum wiring by significant amounts.Photowhit said:
Are we going to heat and a/c the grid next? I mean....it is almost all outdoors. #ExpensiveProposalFirst Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
