24 volt or 12 volt to mppt
cockneybob2
cockneybob2 Registered Users Posts: 18 ✭✭
Hi , is it better to put 2 panels together ln series to form 24 volt to the mppt change controller to change a 12 volt battery bank or does it make no difference
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    Unless you have some shading issues where the panels are located Yes, series wire.
    When you say MPPT that brings up the question, Is your controller a true MPPT controller? There's a lot of bogus Chinese controllers that even have MPPT on the face of the controller.
     Here's an example of a fake.
  • Raj174
    Yes, it is not only better, but necessary. PV in should be at least twice battery voltage to properly charge with an MPPT controller.
    Rick
  • cockneybob2
    Thanks Rick
  • cockneybob2
    Thanks littleharbor 2 it is in fact a cheap Chinese make , should I be worried , can it ruin the batteries if it fails
  • mcgivor
    There are so many knockoffs claiming to be MPPT controllers, some are actually MPPT, others are PWM masquerading as such, but are PWM with a high voltage threshold, please post some links to the controller you have, often more eyes looking can help determine what it is you have.
  • cockneybob2
    Will do , thanks
