Does anyone have a manual or copy of for an old Heliotrope CC-30?
shoebox
Registered Users Posts: 1 ✭
I've set it up again after years in storage and am getting a negative amp reading as well as no "charging" light.
2 AGM in parallel, one 53-watt panel. Seems wired correctly, as panel and battery voltage looks correct. Help?
I think that is circa 1988, I've read that the Heliotrope cc-60 was solid state, but I would guess it has a mechanical relay with contacts that would need to be filed. I think I had to do that to my old SCC IV circa about 1990. Mine were similar to car points (if you are old enough to have filed those). As I recall (from my feeble memory) they were in a clear plastic box, it just had some small tabs through it that were bent over to hold it down.
Don't use a file on contacts, if a strip of plain paper does not clean them up, try the abrasive striker strip from a matchbook.
The fancy plating on the contacts will be destroyed with a file.
