Panel Shade Affect on Entire String
lzhome
Registered Users Posts: 39 ✭✭
Today at 4pm on October 18th I have about 3 inches of shade across the bottom of two panels horizontally mounted. These two serial connected 12v 100w panels are parallel connect to 2 more panels for a 24v string of 4 panels. This shade will only be present during the winter months.
Will this shade have negative effects on the other two panels in the string? I will be installing two more strings in the exact same manner, with same shade.
Oops, put this in the wrong category. can't more so hope a Moderator does it for me.
TriStar MPPT, 8 x 100w PV, MNPV6 Combiner, 4 x 12v 155ah VMAXTanks AGMs and GoPower 2000w PSW Inverter.
Yes, It would be more effective if you can connect the 2 shaded panels in series and 2 sunny panels in series.
FWIW - I connected mine this way with side by side panels connected and found my early and late day shading comes from the sides, so I should really connect mine up and down...lol.
lzhome,
The power output will be reduced about one third in a string shaded in this way. If it were shaded across the short side, output on the entire string would be near 0.
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
lzhome said:Today at 4pm on October 18th I have about 3 inches of shade across the bottom of two panels horizontally mounted. These two serial connected 12v 100w panels are parallel connect to 2 more panels for a 24v string of 4 panels. This shade will only be present during the winter months.
Oops, put this in the wrong category. can't more so hope a Moderator does it for me.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Morning and peak hours are fine, this is late afternoon as I mentioned 4pm.TriStar MPPT, 8 x 100w PV, MNPV6 Combiner, 4 x 12v 155ah VMAXTanks AGMs and GoPower 2000w PSW Inverter.
Personally I wouldn't worry about it, the critical time is the peak period, production would be so low at 4pm, it would be negligible. Sorry missed the 4pm in your OP.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
The shadow will move higher and last longer over the next couple of months though. Around here 2pm in a couple of months will look a lot like 4pm now.Off-grid.
Estragon said:The shadow will move higher and last longer over the next couple of months though. Around here 2pm in a couple of months will look a lot like 4pm now.
Kinda related but different question. I've only installed two panels as a proof of concept on mounting panels on top of my metal building. I check the panels several times a day for shade and alignment and here in the South the panels are covered with dew in the morning which takes a while to vaporize. Does anyone use Rainx or other types of glass polish to disperse water more effectively?TriStar MPPT, 8 x 100w PV, MNPV6 Combiner, 4 x 12v 155ah VMAXTanks AGMs and GoPower 2000w PSW Inverter. -
I wouldn't worry about dew. If there isn't enough sun to vaporize it, the panels wouldn't be producing much anyway.Off-grid.
