How can I tell which model generator I have??
murphysplace
Registered Users Posts: 2 ✭
Hi, Not sure if this blog is even still open. I got a older Air X wind
generator at a yard sale, it needs blades, but I don't know which model
it is, the only number is stamped on the end where the pole would go in,
and it is: 19560 I don't want to buy the wrong blades for it.
Hopefully, someone knows. Try writing air-x ?
Before even considering buying blades, test to make sure it actually works, use a drill to spin it, but then again, since you don't know the model, it would be logical to assume there is no wiring diagram available. Most Air X wind generators seem to be white in color as opposed to the disentery green. The blade bolt spacing may be of help, sorry can't be of assistance, other than that.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
The attached PDF file is the spec sheet for an Air-X model that looks a lot like the one you have, though it's white. There is a phone # at the bottom, maybe they can help.
Rick
