Solar inverter
codger47
Registered Users Posts: 9 ✭✭
Hi guys, this my first post, not even sure this is the appropriate forum.
I live in South Australia, lots of sunlight,
This week,I had a Solax single phase, dual MPPT inverter installed with the solar energy system.. Panels are rated @ 4.9kw.
Two problems;
(1) inverter shows a steady green light,and a yellow light flashes very few seconds. Why is there a yellow flashing light?
(2) cannot connect wifi; my router picks up the solax dongle, showing 'connected no internet'. When I try to access the webpage given in instructions, (11.11.11.1) using tablet or phone, the search times out. I have also tried another address shown on another web page. Same result.
Not too bothered about the wifi, it would be nice, but no big deal.
Right now i'm more concerned about the flashing yellow light
My apologies if I have accidentally come to the wrong forum.
Two problems;
We are in general a US based forum, we do have several forum members from your area... but in general we would have little first hand knowledge about Solax products. Have you contacted the installer, or if you installed have you tried the company?
http://www.solaxpower.com/en/home/Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Hi codger47,
I suspect that the attached file is your product manual. On page 28, it indicates with a green led that the inverter is powered and feeding back to the grid. The flashing yellow indicates the inverter is in communication. Can't help with the wifi if you're using a phone or tablet to access.
Rick
4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
Thanks Rick, I've been trying to get hold of a manual. Most helpful. Codger
Problem solved with help from a friend's nerdy grand child.Fixed in three minutes. Seems I was making a simple mistake. The instructions work if one actually follows what they say rather than what one THINKS they say. A bit embarrassing being shown up by a 12 year old.
