High voltage charge controller
http://www.ebay.com/itm/High-Voltage-PWM-Solar-Charge-Controller-Battery-Regulator-100A-for-PV-System-/122631270342?var=&hash=item1c8d64afc6:m:mvbdWt8_TQNakTsilKokGNQ
Firstly I don't consider myself a pro, but logically if you take an inverter rated at 24V versus a 48V, the 48vV is usually more efficient, so applying that logic and reason, would converting, 120V DC to 120VAC, or 240V as in this case be more efficient, the battery would not nesesarally be larger, just more cells in a string, of a smaller individual Ah capacity1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I think you are right, I think manufacturers are looking forward to the high voltage lithium battery packs for people who would like to "cobble together" a system. Looks like most of the incoming lithium battery packs will be high voltage.
Personally don't care for high voltage DC, but it looks like what is driving the industry currently.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I see the efficiency benefits and potential for a large battery. They have a wide range of voltages available as well. Just seems to be geared toward a niche market. Regulations get more stringent above 48 volts, at least in the US.
Gotta wonder who is using these and what for. Also what kind of reliability it has. Doesn't seem geared toward the hobbiest market.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
I do not see the 400V batteries being a big deal for us. Schneider and Outback are not going that way. Even the car market is looking seriously at 48V. Remember that the high voltage battery has a different cooling requirment/safety and still has some form of DC converter plus the BMS.
I think you guys are looking at last years news. Even Tesla has gone to 48V. Look at that thing the model 2. How many things are just wrong for offgrid. The masses may love Elon but....
Thank you Dave, I hadn't heard Tesla had gone to 48 volt! good to my ears!Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
One of the reasons Schneider abandoned an all in one this year was the 400V box does not surge well without using up all the cost savings in the design. The Hi voltage RESU10H form LG is only available with an inverter that is 240 vac and needs a transformer to produce 120vac in an outage :'( SMA will have something more intelligent in the fall for the LG HV bank.
At my place, I place a very high value on being able to surge for my fire pumps at the same time as all of my other loads (Wifey)........
Hi Dave, I can't tell if this comment is in the right thread or not, referring to post #5. But as to the 48 volt Tesla Powerwall, it's a no go, isn't it?
It (ac version 48vdc) is what is currently being installed a hundred miles or so from Corporate in Palo Alto CA. It already does not look the same on the outside as my screen shot. The Ap was not working so another truck roll. They are in the first month shipping model 2 to installers and I doubt these will ever get out there for do-it yourself. One step further, they will only be used on e-bay with zero warranty. Solar City and their "people" only. Most of the Panasonic cells sold on e-bay are rejects from Tesla.
I have seen other brands that have both a ~48 V and a hi Voltage model as well, had the same question about what application it fit..
westbranch said:I have seen other brands that have both a ~48 V and a hi Voltage model as well, had the same question about what application it fit..
This 100 amp controller apparently has 96, 110, 120, 192, 216, 220 and 240 volt battery models available. It fairly boggles the mind. Then again my mind boggles fairly easily.2.1 Kw Suntech 175 mono, Classic 200, Trace SW 4024 ( 15 years old but brand new out of sealed factory box Jan. 2015), Bogart Tri-metric, 460 Ah. 24 volt LiFePo4 battery bank. Plenty of Baja Sea of Cortez sunshine.
industrial UPS use high DC voltages.
The Tesla model 2, that is just out there now, is 48vdc. It has an industrial version that has a 48VDC step up for high voltage just as the LG Resu 10H does. It is very easy to build a step for any voltage that is required, within reason."we go where power lines don't" Sierra Nevada mountain area
