temp for windy nation lifetime
DJuan222
Registered Users Posts: 26 ✭✭
I was looking at windy nations own info on how to get the most years out of their batteries and they say about 50F
to get 9-12 years...I had to LOL for real, not even in my house is cool enough. I guess I need to get a small freezer and
let it be a battery box powered by the batteries everyday just to protect the investment in batteries.
At current temp they say about 3 years...thats not ok !!
JC
JC
All batteries are hurt by heat, although some more than others. Any battery will las a lot longer at 50°, not just those made by one company.
The batteries that I deal with will see a 50% decrease in service life with a 10 deg C, above 25 deg. C. Remember that this is average temperature for 8760 hours per year. In practice, we see a 6-8 year lifespan in hot climates and 10-11 years in cold climate areas.
As a reference point, 12v 1,000 ah battery banks buses running the Southwest Desert highways often see 140F or higher, and they tend to make it 5 years.
My off grid customers in extreme high temperature areas will often dig a recessed area in the ground for their battery room. Some have used water cooling and/or AGM batteries brought indoors and held to around 85F on the really hot days.
Worst case I have ever seen are DHS remote surveillance packages deployed near our southern border. Metal boxes with small vents but no power exhaust, sitting in the sun. Only a 3 to 4 year life with shallow cycling. Same equipment package parked at a higher elevation provides 5-6 years.
Marc, I have a question. Is there an appreciable difference in life time when the batteries are in a hot environment and not cycled, as opposed to being regularly cycled? My system in Baja gets shut down for 3 months in the summer with only a small trickle charge to maintain it.
Marc Kurth said:My off grid customers in extreme high temperature areas will often dig a recessed area in the ground for their battery room.
Hi Marc
Can you post a few pictures of recessed and water cooled batteries. If you have them it would be appreciated.
Regards
Mark- Main: Infinisolar 3+ (3kv) 48V Grid-Tied PV=3410w NE facing (8x 330W JASolar, 3x 310W Yingli), + Victron MPPT 150/60 @1240w SW facing (2x 310W Renesola, 2x 330W JASolar), Pylontech US3000, Victron BMV 700, 6 string combiner box with PV isolator switch, subDB for inverter supplied power.
- Draadkar: Axpert 800w, 24V, 8x 12V - 105ah Leisure Batteries 400ah, PV=480 (2x 240W ElChepo), Victron BMV 702 for laptop, relays backup.
- ICC for management, automated switch over and monitoring, pushing data to EmonCMS and PVOutput.org (Aloe Ridge Farm).
- Weather from personal weather station using Weather Display.
My understanding is temp is a factor even when stored. The higher temp speeds the chemical reaction, so self-disharge happens faster. In hot conditions, normal float voltage may be high if uncompensated.Off-grid.
Im going to measure a magic chef mini fridge in 4.4 cu and see if the 3 batteries will lay on their side, I think height is no problem, I think depth is to shallow but will see...might be a neat project thats not to $$$
littleharbor2 said:Marc, I have a question. Is there an appreciable difference in life time when the batteries are in a hot environment and not cycled, as opposed to being regularly cycled? My system in Baja gets shut down for 3 months in the summer with only a small trickle charge to maintain it.
Heat is a killer of all batteries. This is the case with a battery inside a laptop, a starter battery under the hood of a car and stationary batteries in a tin shelter under the hot sun. As a guideline, each 8°C (15°F) rise in temperature cuts the life of a sealed lead acid battery in half. This means that a VRLA battery for stationary applications specified to last for 10 years at 25°C (77°F) would only live 5 years if continuously exposed to 33°C (92°F) and 30 months if kept at a constant desert temperature of 41°C (106°F). Once the battery is damaged by heat, the capacity cannot be restored.
mini fridge project step 1 complete now for wires, holes drilled in top
Wow, I'm surprised the plastic bottom, even with a plywood spreader, is holding up. Or that the bottom battery is not going to get damaged by the weight above it.
The batteries appear to be mis-matched. The terminals are different on them.
Someone here disassembled a water cooler to create a chilled water bath. With his hot climate, it made sense to me. Water is a good way to store cooling - so you can run it while the sun shines and then coast through the night.
Solray said:The batteries appear to be mis-matched. The terminals are different on them.
same windy nation batteries but yes the terminals got changed, to many people broke off the style on the top 2 it seemed
mike95490 said:Wow, I'm surprised the plastic bottom, even with a plywood spreader, is holding up. Or that the bottom battery is not going to get damaged by the weight above it.
When I buy batteries to use in an array, I always get consecutive serial numbered batteries for the best compatibility. Not everyone does this and it could be overkill, but with the cost of batteries, why not? Better safe than sorry.
Anyways, good luck with this project, it is interesting at least. -
well heres the finished product.....been running it for awhile in the days garage is 110F but the batteries get about 50F in the day
total extra cost 149 fridge and silicon 3
something I learned, panels my be at 17v but amps need to be up and angle of incidence def help the amps
that 5.45 amps is noon 17.5 V but panels are 45degrees to the side so I turn them thru the day and get 8+amps keeps everything 100%
What gauge wire do you have coming from your panels, and how long a distance? That wire looks awfully small.
its 12 or 14 for about 15 feet I have 10 that Im going to change to but just wanted to finish this project first
- 231 Forum & Website
