electrolyte not cristal clear in 1 cell
dapago
dapago Registered Users Posts: 62 ✭✭
Hello guys,
this is morning I checked my batts cells and noticed that the electrolyte in 1 of the cells was not cristal clear like the others. The batts are only 1 year old Trojan T105RE.
Is it something normal and if not what can be done?
thanks in advance.
Off-grid. Midnight Classic 200. 2,480W array. Magnum Inverter MS4448PAE. 225Ah*8 @48V Trojan T105RE Smart Carbon. MN bkrs box.
  • Estragon
    What is the specific gravity of the cell?
  • dapago
    edited June 2017 #3
    I first nivelled the cell with a bit of distilled water then took the SG . it reads 1220 but the reading could not be accurate because I just added water. I was thinking to EQ tomorrow morning.
  • mcgivor
    Discoloration could indicate over charging, but as it's only in one cell perhaps there was an accumulation of gas which burped,  stirring the lead sulphate, usually this clears by the next day. The following is an excerpt from Rolls tech support.
    Electrolyte Characteristics
    In new batteries, electrolyte should be clear of debris or any discolouration..
    During normal use you may notice the electrolyte in the battery cells has changed colour or become cloudy. Typically, this is not cause for concern.
    Murky light grey is normal under regular use.  This is caused by sulfation being removed from the battery plates, which is natural and part of proper battery maintenance.  This debris will be most visible following corrective equalizations.
    Murky dark grey or black electrolyte suggests the batteries have been overcharged or may not be properly maintained.  Please refer to your Rolls Battery User Manual for instructions on maintenance and corrective equalization.
  • dapago
    edited June 2017 #5
    Thank mcgivor. The color was light grey and cloudy. Only 1 cell had this characteristic. Should I perform an EQ? In any case, is it a good idea to take part of the electrolyte and replace it with distilled water?
  • mcgivor
    edited June 2017 #6
    Doing an EQ will mix the electrolyte, check the SG afterwards, do not remove electrolyte and add distilled water, that would dilute it and reduce the SG. Are you following Trojans recommendations for charging voltage etcetera?
  • dapago
    edited June 2017 #7
    Yes I am. On that side I think I am ok.
     I was just preoccupied with the electrolyte being cloudy on 1 cell.
    After performing an EQ, will the electrolyte on that particular cell clear up with time or will it always keep this color and cloudiness?
    there is one thing I have changed on my CC setting and that is the automatic EQ. Before I used to do it manually every month after taking the SG and since 2 months I use the automatic EQ set for  every 30 days
  • mcgivor
    In my experience it usually clears, but will appear when performing an EQ, which is, in itself, a controlled over charge, stirring the electrolyte, don't over EQ, it should only be done when needed to prevent cell drift.
  • dapago
    When needed? Trojan recommend to EQ  every 30 days. I have read somewhere that it is only needed when SG reading is under the 100 % charge value in float.
  • mcgivor
    Trojan has recommendations, see link below, under equalization
    http://www.trojanbattery.com/tech-support/battery-maintenance/
    I don't think Trojan presents a solid front on this, some manuals state to only equalize when the cells are out of balance, but I can show you a video where they suggest every 30 days.
  • mcgivor
    Reading further into the document under discharging it states that : Many experts recommend operating batteries only between the 50% to 85% of full charge range. A periodic equalization charge is a must when using this practice.
    Under Equalization it states : Many experts recommend that batteries be equalized periodically, ranging anywhere from once a month to once or twice per year. However, Trojan only recommends equalizing when low or wide ranging specific gravity (>0.030) are detected after fully charging a battery.
    Same source
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,186 ✭✭✭✭
    Funny how they refer to "Many experts."
  • mcgivor
    Thats what I was wondering,  thought they were the "experts " on their own products, at least.
  • Estragon
    It seems to me that there are so many variables - usage patterns, temperature, charging profiles, etc., blanket recommendations aren't all that useful. I tend towards the notion that if it ain't broken, don't fix it.
    Dave Angelini Solar Expert Posts: 6,992 ✭✭✭✭✭✭
    The business model is to sell batteries!
    We do a preventative EQ every 90 days for one hour whether we need it or not.
  • mcgivor
    Just don't wait till it's broken, proactive response to an apparent problem is usually the best approach, in many ways Trojans recommendations of observing SG to determine when to EQ  makes sense, careful monitoring of the battery is essential, they can't cover every situation, in off grid an EQ is probably required more often due to the charge and discharge cycles, but the SG is the real indicator of battery health. Every situation is different, keep your finger on the pulse of your particular system, monitor all parameters, don't focus on one. My opinions some may vary.
  • Estragon
    By "broken", I mean when SG is low and/or meaningfully different between cells. I try to check all SGs every couple of months, but have done 1-1.5hr EQs on spec at times if I don't get a regular check done.
  • Solray
    Solray Registered Users Posts: 246 ✭✭✭
    Everyone thinks they are an expert. :)
