Capacity capped by Micro-inverter
MikeBloom
Registered Users Posts: 3 ✭
If I pair an Enphase IQ 6+ MICRO (290 VA) with an LG320N1C-G4 is the capacity of the Enphase going to limit my peak generation capacity.
In other words, does it make sense to install a panel with production capacity higher than 290W when paired with this micro inverter?
Thanks, Mike
Thanks, Mike
In general, a cost effective match is an mppt controller (gt inverter or charge controller) that is at least 77% of the panel's rated wattage (standard test conditions are higher output vs real operation under full sun on a warm day). You will not lose much power.
In practice, you need to check the web site / manual for the micro inverter. They have certain requirements (wattage/voltage ratings of the solar panel) to keep their UL/NRTL Listing.
- BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
Yes (but rarely, so don't worry) and yes. Enphase suggests 235W to 400 W panels. IMO, a panel around 360W is typically ideal and even a little higher panel output than you selected would be optimal.
- 234 Forum & Website
