Used Solar panel with "Blister" and Brown Patches
bigbrovar
Registered Users Posts: 32 ✭✭
Hi guys. I have two questions.
First I intend to upgrade my off-grid solar setup by addition more panels. I got 2 used 220w panels from online but when they arrived I found that that one of the panel has small opening at the back (see attached) like a some blister. The corresponding surface area in front of the panel also bares mark of defect like a short circuit.
Both panels also had some patches of brown at the top right and left side and bottom of the panels. The brownish of the usually white part of the panel.
I ran a test on the panels using a multimeter and got good result. IMP for each of the panels (the one with the "wound" and without) was 7.9A . The VOC was 35. This was any 13:30 on a clear sky 38C day.
The panel stickers were out so no way to reference the above figures to manufacturers specs although seller claim them to be made by Lorentz the German solar company.
I attached each of the panels to a pwm charge controller connect to a 40A 12v AGM battery. (This was late afternoon around 15:30) I recorded about 3.4A, 20v) from each panel. I took out an older PV which I have hard for some time has a reference and it too gave similar output.
Here comes my Question:
Can I still use this panels? are they any good and what could be the cause of the brown patch, also I would have imagined that the panel with the "blister" would deliver a significantly lower power compared to the rest but the blister didn't seem to affect it. What could be the reason for this?
Is it something I can ignore or something that would get worse.
If they are producing power then I would use them. Keep and eye on them but why not
- Main: Infinisolar 3+ (3kv) 48V Grid-Tied PV=3410w NE facing (8x 330W JASolar, 3x 310W Yingli), + Victron MPPT 150/60 @1240w SW facing (2x 310W Renesola, 2x 330W JASolar), Pylontech US3000, Victron BMV 700, 6 string combiner box with PV isolator switch, subDB for inverter supplied power.
- Draadkar: Axpert 800w, 24V, 8x 12V - 105ah Leisure Batteries 400ah, PV=480 (2x 240W ElChepo), Victron BMV 702 for laptop, relays backup.
- ICC for management, automated switch over and monitoring, pushing data to EmonCMS and PVOutput.org (Aloe Ridge Farm).
- Weather from personal weather station using Weather Display.
The brown staining looks like water intrusion. Not good These panels have a short life expectancy with compromised lamination. The burnt cell is clearly a problem. You really need a MPPT controller to connect these 60 cell panels to a 12 volt battery. I'm sure when properly connected the damaged panel will not perform correctly, under load. Your test with a multimeter was the Isc, not Imp. This is really meaningless without voltage flowing. You need to put a load on this panel when testing it it
littleharbor2 said:The brown staining looks like water intrusion. Not good These panels have a short life expectancy with compromised lamination. The burnt cell is clearly a problem. You really need a MPPT controller to connect these 60 cell panels to a 12 volt battery. I'm sure when properly connected the damaged panel will nor perform correctly, under load. Your test with a multimeter was the Isc, not Imp. This is really meaningless without voltage flowing. You need to put a load on this panel when testing it it
The cell may be compromised, leaving the ballance of cells working, sealing with silicone may prevent water intrusion at very least, the panel as a whole may still have some life left but I would seriously consider a plan for replacement in the future.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
If you can remove the aluminum frame on the ends of the panel you might be able to clean and apply some latex, urethane or silicone. You could use these panels for learning about solar but I wouldn't put them in any kind of "mission critical" use. Hopefully you got a really good price on these panels. Personally I wouldn't pay any more than $20.00 a piece for them.
I'd use epoxy if trying to fix. I also wouldn't mount to anything flammable!Off-grid.
The front side last photo, discoloration and trails of solder(?) appears to be a condition known as Snail trails, I suspect the brown 'thing' was a cause and the trails an effect, Here's some more information about it;
http://ac.els-cdn.com/S1876610213013957/1-s2.0-S1876610213013957-main.pdf?_tid=ea1b10fe-401c-11e7-bcf3-00000aacb360&acdnat=1495588038_daa3243f5d7e95712fb67ecbc72cc17b
I've also heard of the 'water marks' discoloration called this, but I usually think of that as a loss of vacuum seal. I don't know the long term effects of the snail trails, the loss of seal or lamination, might cause problems with oxidation. I have some very old monocrystalline panels (1980) that I tore the backing material back in @2002, I used 'tool dip' or 'liquid electrical tape' to cover the holes. they are still functional panels today, even though they show some oxidation.
I have used the same solution when I purchased some warehouse damaged panels, and they have not shown any loss of lamination visible on the front side, but they had an addition protection sheet between the backing and the cells. (Suntech)Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Flexseal
looks like lightning damage, from a stray streamer, What else melts a hole in aluminum ?
High voltage arc from a battery, welding sparks, acids, etc.
- 230 Forum & Website
