Solar rookie seeks help with 15-amp miter saw
jackypaper
Registered Users Posts: 14 ✭✭
Hello, friends. I've been chatting with BB., who has been gracious in his responses when helping this solar n00b with beginner-level questions. He suggested that I post here.
My goal: To operate a 15-amp saw with solar power
My current set-up: Two 100-watt panels --- SunSaver 20L Controller --- two 6-volt series-connected Tojan T-105s --- 450-watt inverter.
My plan: Simply replace the small inverter with a 3000-watt inverter to provide for the saw's needs of 1800 continuous watts and 3600+ watt start-up
My questions: (1) Is running that saw for extremely short periods of time (like, two seconds per cut) possible with a 12-volt system? (2) If so, how large of an inverter is required? (3) Do I need a 24-volt system instead if I hope to run that saw at all?
Thank you all so much for taking the time to help a solar-power beginner.
If it has a universal motor, it should work to add a 15A dimmer. This would allow a softer start and far less startup amps.
I usually use my 3000W genset with the sliding miter-saw, but tried it on the 2000W generator last week (continuous 1600W ) and it would suck wind every time I spun it up... so it will put a big drain on your 2 small batteries in all likelihood.... use the genny if you have one... and yes, 24 Volt... Look at the Exelteck inverters 2000W/4000 surge
It would be cheaper and more practical to get a 3500 watt generator.4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset.
For this application, you might want to consider using AGM automotive starting batteries instead instead of deep cycle. Starting batteries have thin plates with lots of surface area for short bursts at high discharge rates. Don't draw them down deeply though.Off-grid.
jackypaper said:My plan: Simply replace the small inverter with a 3000-watt inverter to provide for the saw's needs of 1800 continuous watts and 3600+ watt start-up
It is very likely a saw spinning up will not be the maximum load, it will likely be <1500 watts with a peak load when cutting into hardwood and binding. I have started my Table saw on an 1800 watt inverter (Prosine with a 2900 watt peak), it's a Delta pulley driven, I think rated as 15 amp.jackypaper said:My questions: (1) Is running that saw for extremely short periods of time (like, two seconds per cut) possible with a 12-volt system? (2) If so, how large of an inverter is required? (3) Do I need a 24-volt system instead if I hope to run that saw at all?Another Option;
Buy a Used DeWalt 18 volt saw, plan on the batteries to be dead but be sure to find one with a charger. <$100 used Buy the newer 6 1/2", buy a couple 2000Ah aftermarket pod batteries from Amazon $60. The chargers produced after 2000 will even work on a square wave inverter (some of the earlier ones don't)
I framed up an 'A' frame with the old trim saw (smaller 5 3/8th") I had a solar supply much like what you have and purchased a new drill and saw kit in 2001. They are limited, but less so than 2 second cuts.
Raj174 said:It would be cheaper and more practical to get a 3500 watt generator.
You know, this might end up being the better option. -
From what I've read, I assumed that an 1800-watt saw would require at least twice that amount for its initial start-up. Is that not accurate?
jackypaper said:jackypaper said:My plan: Simply replace the small inverter with a 3000-watt inverter to provide for the saw's needs of 1800 continuous watts and 3600+ watt start-up
It's not under load, for something like a compressor it's under a large load and making that first cycle is it's largest load. I don't "know" but would think it's unlikely. You wouldn't happen to live in Missouri? ExelTeck 1100 watt inverter will start and run my 12 amp chainsaw, I do it regularly. Exeltech will clip it's wave to run higher wattage items at a different power factor (I don't understand how that works, but it does.
I do worry that it would be frustration only being able to make short run cuts. I like the idea of using the solar to power the tools, and would hope you will consider the DeWalt Power tool option. People are moving to the newer lithium powered tools which makes a lot of sense, but the older pod battery tools can use the lithium batteries with an adapter and can be found very cheap now. I did a quick search on Craigslist and found a new set in KC MO drill, circular and recip 1 battery and charger for $125 and a saw and battery and charger for <$90 in St Louis. likely most pawn shops would have them as well.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
I run a skill saw and mig welder off my samlex 2000w pure sine 12v input inverter off my 72ah LiFePO4 battery. It works fine.
Just as a follow-up, in case anyone is interested, I'm now successfully running my 15-amp miter saw off of two 6-volts and a 2500-watt inverter. It's a thing of beauty . . .
jackypaper said:Just as a follow-up, in case anyone is interested, I'm now successfully running my 15-amp miter saw off of two 6-volts and a 2500-watt inverter. It's a thing of beauty . . .
Mostly during the day with the solar producing?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Photowhit said:jackypaper said:Just as a follow-up, in case anyone is interested, I'm now successfully running my 15-amp miter saw off of two 6-volts and a 2500-watt inverter. It's a thing of beauty . . .
Correct. I've powered my fluorescent lights and stereo at night, but I put a strain on the batteries with the saw only during the Texas sunshine. -
Very happy to hear that this is working well for you.
Take care,
Hey @jackypaper I'm in an identical situation. Did you end up getting a 24v inverter and that solved the issue?
I have a similar setup - here's a visual diagram of what I have: https://miro.com/app/board/o9J_lP4KTdE=/
- Six 100 watt Renogy panels in Parallel.
- Four 6v 200Ah batteries. Two Trojan T-105's and two Duracell's in series and parallel for 12v 400Ah.
- One GoWise Pure Sine Wave 3000/6000w 120v inverter (25/50 amps?).
- One 40Amp Renogy Rover Solar Charge Controller.
What is the DC voltage on the inverter input when the saw tries to start?I always have more questions than answers. That's the nature of life.
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
