24v, 12v, Panels, Charge Controller and Battery
BlakeFleming85
BlakeFleming85 Registered Users Posts: 33 ✭✭
Since I'm a raw beginner at this, I think I've missed some simple points that make a huge difference.  Can someone clarify for me?
I thought if you have a 12v battery or battery bank, that you had to have a 12v panel or Array of panels.   Apparently this is not true.  Resources say that I can have a 24 volt panel connected to a CC (either PWM or MPPT) and the CC will convert the incoming power to match the connected 12v battery.  Is this true?
Also, the resources say that I can even mix 24v and 12v panels  and there is no harm done to the CC or the 12v battery.  Of course, connecting the PA in Series or Parallel makes a big difference in the effectiveness of the current transferred to the battery.
Does this mean that any reliable CC will safely do this as long as I'm not overloading the 10amp, 20amp, etc. rating?
Finally, in doing all of this, what is the absolute bottom line in battery charging?  Is the main goal to get the highest Amps possible?  Are the Amps what I'm actually trying to improve the most for sake of charging a system, as opposed to getting minor adjustments from 13.1 or 13.6 or 14.1volts?
    Photowhit Solar Expert Posts: 6,011 ✭✭✭✭✭
    Charge controllers;
    MPPT type will convert the voltage to proper charging voltage for the battery bank, They will down convert the voltage and use most of the wattage coming in. You will want to have @ 30% more voltage than is required for charging (@14volts per 12v system) so typically you will want 12volt panels in series.
    PWM do not down convert, rather limit the voltage coming in. While higher voltage panels can sometimes be used (check the controllers limits) the 'extra' voltage is just lost. When correctly sized panels are used there is about a 10% loss using this type charge controller.
    Panels or strings of panels should be with in 10% of each other to prevent large system losses and avoid confusing MPPT type controllers searching for best conversion.
    Charge controllers, control the voltage presented to the battery bank. These voltage parameters vary by battery type and manufacturer. Check with the manufacturer for proper set points.
  • BlakeFleming85
    Thanks!   So, ONLY a MPPT CC will allow me to efficiently use the 24v panels with a 12v battery bank?
    edited March 2017 #4
    Yes! Often in small system <1000 watt array, it can be cheaper to use an PWM controller. large panels can be less than half the cost but come with high shipping rates. In addition PWM controller are typically 1/3rd the cost of MPPT controllers.
  • Estragon
    Another factor is distance to array. For longer runs, using an MPPT controller allows for more panels in series, higher voltage, lower current, and thus smaller wire.
  • BlakeFleming85
    The smaller wire for the run is a great help to one application I'm looking at.  Thanks.
  • BlakeFleming85
    As asked in the initial question:
    What I mean is, What is the factor that is most important to the charging of batteries?  Of course, I need the proper voltage, but if one CC gives a tiny edge over another (PWM vs. MPPT) in voltage, is that less important than one that gives better amperage output?  Same question for the 24v vs. 12v Solar panel array... Am I better off to choose between the, based upon whichever will dump more amps into my battery array?
    To elaborate on my answer;
    "Charge controllers, control the voltage presented to the battery bank. These voltage parameters vary by battery type and manufacturer. Check with the manufacturer for proper set points. "
    The charge controller will maintain proper charging voltage. Most PWM will have a couple choices of charging profiles and the more expensive/higher quality will let you set your own charging voltage points. MPPT type will have a microprocessor of some type and are typically offer user settings.
    Both should maintain very similar voltage set points for your battery bank...
    The choice typically is a straight price/value assessment. MPPT typically will deliver about 10% more energy and are somewhat more flexible, but require a higher incoming voltage. PWM will tend to be cheaper, but work cost effectively with a more narrow VMP panel range.
  • BlakeFleming85
    Thanks for the elaboration on your previous statement.  Do you know of a website or something that I can view comparisons for different voltages on Panel Arrays?  I'd like to see the differences in amperage that is output to the battery via both PWM and MPPT charge controllers.  It seems like the videos I was watching showed much more substantial amperage outputs to the batteries when using higher voltage panels with a MPPT controller.
    I am not aware of any...
  • mcgivor
    Some reading material to help you better understand PWM & MPPT
  • BlakeFleming85
    I appreciate that.  Thank you!   Can someone comment to tell me if installing something like this would help me with simple, but helpful information for monitoring a small system with only about 200w of PA?   It is a
    LCD Display Digital Current Voltage Power Energy Meter
    https://www.amazon.com/gp/product/B013PKYILS/ref=ox_sc_sfl_title_3?ie=UTF8&smid=A1T3LOAKNUUM9N&th=1
