Posting Query
Brianellul
Solar Expert Posts: 95 ✭✭
How can I post jpegs in my posts? I did notice the Manage Attachements button but I'm not sure what to do after that. I would like to incorporate a couple of pics in my post
Re: Posting Query
Click on the paper clip just right of the white smiley face
Select from your computer, the select your picture from your pc then upload it and your done. Like this ! -
Re: Posting Query
Hmmm, I don't have the paper clip! Is it something which the Administrator has to enable? -
Re: Posting QueryBrianellul wrote: »Hmmm, I don't have the paper clip! Is it something which the Administrator has to enable?
methinks he's got a different board in mind. I do it by going to Advanced message edit, and scroll down to the
Attach Files
Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt zip
click the MANAGE ATTACHMENTS button, and continue from there.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Posting Query
I dont understand when I post a reply as now, I have on the top row above me from left to right, Fonts/Sizes/Colour of fonts then a white smiley then the paper clip then undo and redo arrows, Im posting in the same forum so we should all have the same ? -
Re: Posting Query
nigel,
i see what you are refering to, but even i hadn't tried attaching with that and i'm giving it a go here.
yes it works fine. i was using manage attachments and is the same thing really. -
Re: Posting Query
Niel, somehow CT managed to imbed some images in a posting as opposed to attachments. I think that is the OP's question vs using the attachments facility. see post #26 in ' I have a batt. monitor question'. I dont know how she did it either...
Eric
Re: Posting Query
I think there are two ways to add/embed pics. One is to use the composition attachment feature using the "paper clip" icon. The other way is to use the "Insert Image" button (yellow rectangle with landscap and Sun) to attach an image from a server using a URL. For example, here's an attachment from OutBack:
- 231 Forum & Website
