Posting Query
Solar Expert Posts: 95 ✭✭
How can I post jpegs in my posts? I did notice the Manage Attachements button but I'm not sure what to do after that. I would like to incorporate a couple of pics in my post
Welcome!
  • Solar Expert Posts: 705 ✭✭
    Re: Posting Query
    Click on the paper clip just right of the white smiley face
    Select from your computer, the select your picture from your pc then upload it and your done. Like this !
  • Solar Expert Posts: 95 ✭✭
    Re: Posting Query
    Hmmm, I don't have the paper clip! Is it something which the Administrator has to enable?
    Re: Posting Query
    Brianellul wrote: »
    methinks he's got a different board in mind. I do it by going to Advanced message edit, and scroll down to the
    Attach Files
    Valid file extensions: bmp doc gif jpe jpeg jpg pdf png psd txt zip
    click the MANAGE ATTACHMENTS button, and continue from there.
    Re: Posting Query
    I dont understand when I post a reply as now, I have on the top row above me from left to right, Fonts/Sizes/Colour of fonts then a white smiley then the paper clip then undo and redo arrows, Im posting in the same forum so we should all have the same ?:confused:
    Re: Posting Query
    nigel,
    i see what you are refering to, but even i hadn't tried attaching with that and i'm giving it a go here.
    yes it works fine. i was using manage attachments and is the same thing really.
    Re: Posting Query
    Niel, somehow CT managed to imbed some images in a posting as opposed to attachments. I think that is the OP's question vs using the attachments facility. see post #26 in ' I have a batt. monitor question'. I dont know how she did it either...
    Eric
  • Registered Users, Solar Expert Posts: 1,832 ✭✭✭✭
    Re: Posting Query
    I think there are two ways to add/embed pics. One is to use the composition attachment feature using the "paper clip" icon. The other way is to use the "Insert Image" button (yellow rectangle with landscap and Sun) to attach an image from a server using a URL. For example, here's an attachment from OutBack:
Welcome!
