Chinese Panels for Offgrid 48v DC system in Australia
Rayson
Rayson Registered Users Posts: 21 ✭✭
Has anybody got suggestions for competitive Solar Panels out of china.
I am using 48v DC and do not require any help with the power management electronics.
We have Batteries in Australia, given their weight and price, there is likely to be little gain in importing them.
Anyone with info on Chinese suppliers of Solar Panels?
Thanks,
Ray
Australia
  • mcgivor
    edited January 2017 #2
    There are many panels made in China and there are good quality ones, look for certification such as CE, Ul, Tuv and so forth, I have Schutten panels made in China, they carry several certificate markings and are good quality,  but I've seen some that have no international compliance certification, and claim some rather high self ratings, would stay clear of those.
  • Rayson
    Thanks for the introduction.
    Your advice will be very handy.
    Ray
    edited January 2017 #4
    How many are you thinking of getting?  I bought 2 pallets of 12v Panels several years back and   all is well so far.  I paid ( dearly) for 2 sample panels, to get my hands on , to ascertain the quality, Ask for the flash test results too... I believe they must do a rough sort of the cells before assembly of the panels.
    Panels are designed/made with a certain W output expected and then sorted after the flash test, that verifies the output. So some might be from a higher expected output class that didn't make it, still good though for the next class. The test results will show varying Volts and Amps but above the variance for the group eg + 5% -3% or ?
    IO chose to go for the ones in the middle of the class..
    hth
  • Rayson
    edited January 2017 #5
    hth
    I believe we need about 2kw at about double the voltage of 48v battery bank as a minimum module.
    Depends on the cost and viability to expand, open question!
    There is the possibility of doing something similar to yourself, obtaining Samples first then decide.
    With a lot of companies offering free or very cheap freight charges out of China into Australia, it cannot hurt to inquire.
    Ray
    the samples would probably be sent by courier, that is the expensive part... shipping in bulk is very inexpensive...
  • softdown
    softdown Solar Expert Posts: 4,029 ✭✭✭✭
    The vast majority are made in China. I might ask this board instead of getting samples shipped. Tell us a few brands of interest and wait. Most of us are old solar pro$.
  • Rayson
    Will do, done a google search on Schutten Panels to find very mixed opinion.
    Happy to hear anyone's experience or suggestion for panels, where ever they can be sourced.
    It may workout best to buy panels already imported into Australia, just keeping all options open.
  • softdown
    Importing direct from China aways gave me the heeby jeebies. Then you have to go through the procedure$ at the shipyard. I doubt it would be worthwhile for 2Kw.
    However, it is likely to be worthwhile to drive to a dealer instead of shipping. Summertime down under. Get crackin' mate.
    importing Then you have to go through the procedure$ at the shipyard.
    Well you just hire/enlist the services of a Customs broker... cost me $75 and then have them arrange shipping to your chosen location cost ~ $300
    btw 2 pallets is > = 4 Kw
  • Rayson
    edited January 2017 #11
    Yes, I have imported 50KG lots of Custom made Rare Earth Magnets directly from Chinese Manufacturer.
    The company was happy to organize shipping, same with Electronics Manufactures.
    Never had to use a Broker, but it is an option.
    2 pallets at 4 Kw would be a good start.
    There is quite a Gap between my interests and the Suppliers interest in Australia.
    Cracking along just nicely.
    Thanks for sharing westbranch.
