converting a solar exhaust fan to 120 volt ac
Leo
Registered Users Posts: 1 ✭
Is it possible to convert a solar powered exhaust fan to 120 volts ac? If so... please explain!
Anything is possible, within reason, more details, what is it you have?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Leo said:Is it possible to convert a solar powered exhaust fan to 120 volts ac? If so... please explain!
Perhaps, but for the most part it would be counter productive. Most inverters have a search mode which draws very little power. If it was providing ac for a fan it couldn't run in search mode and use more electric.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Would a battery charger work? Might need a battery between charger and fan.Off-grid.
Sorry, I mis-read, Old age...lol. I though it was an inverter exhaust fan.
Yes, you need to figure out what voltage the fan works at. Measure the voltage coming off the solar panel and find an ac adapter for that dc voltage to ac. The voltage open circuit voltage of the solar panel will be about 130% of the fans dc voltage.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
You need to be more clear. Do you have a DC fan running off of a PV panel?Leo said:Is it possible to convert a solar powered exhaust fan to 120 volts ac? If so... please explain!
All my AC exhaust fans run off solar power, but it's inverted from the panels/batteries.
If you have a 12V DC fan, you need a compatible 12V power supply fed by 120VAC How many amps does the fan draw?
