RUNNING 12V DIRECTLY FROM ARRAY
nasty
Solar Expert Posts: 35 ✭✭
Hello
Did a search but I'm not sure I'm asking the question correctly. I have 4 Kyocera 140w panels that charge a battery bank about 75' away. 12v system connected with buried 4/0 cable to the CC and batteries. I need to operate a 12v pump for a shower house that is about 15' away from array. Instead of running wire 75' from the batteries to the pump can I just connect directly to the array so there isn't as much line loss or would that be negligible? Thanks for any help.
A DC-DC isolator converter can convert 9 to 18V to a stable 12.5V, available in various capacities, Samlex has them and possibly other manufacturers. You don't want to overvoltage the pump.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Do you have more information on the pump specifications (amps, volts, watts, max voltage, etc.)?
There are pumps that can be run directly from panels but they tend to be expensive.Off-grid.
I have a Shurflo 2088. 12V 3.5GPM 5.8-9.1 Amps
mcgivor said:A DC-DC isolator converter can convert 9 to 18V to a stable 12.5V, available in various capacities, Samlex has them and possibly other manufacturers. You don't want to overvoltage the pump.
It sounds like you should use a Linear Current Regulator if you want to avoid the batteries (good idea if this work for you):
https://www.solar-electric.com/7amplincurbo.html
mcgivor said:A DC-DC isolator converter can convert 9 to 18V to a stable 12.5V, available in various capacities, Samlex has them and possibly other manufacturers. You don't want to overvoltage the pump.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
mcgivor said:Not exatly sure what is meant by the panels needing complex MPPT tracking, unless you were referring to the controller used down stream, I asumed it was not MPPT as the array is 12V and the use of #4 /0 conductors , if it were a simple PWM perhaps it would be of less concern as it would simply be a volt drop and a PWM CC would just compensate, as it would when a cloud passes. If you were referring to a MPPT CC your rationale makes sence. Just ideas for solutions.
PWM is on/off. If you connect it to your pump it may not like it since it will be slamming on and off all the time. (Equivalent to you turning the pump on and off rapidly, 60 times a minute or so.)
As BB mentioned, LCB's (current boosters) are designed to do exactly this - power a pump directly from a solar panel.
As BB mentioned, LCB's (current boosters) are designed to do exactly this - power a pump directly from a solar panel.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I am starting to think running a large enough cable from my 12v distribution center 75' away to the pump might be the way to go. Need to see how big of wire it will take to minimize line loss. That way we can shower when there is no sun. Thanks for all the help.
The array is NOT 12V. It is an 18V array for charging a 12V battery. Wire a pump directly to an 18V panel and you will be buying a lot of pumps. Trying to wire a 18-12V DC-DC will not work, at some point in the day (like when the PWM charger first kicks on and effectively drops the panel voltage to 12V) it will collapse the Panel voltage and no more pumping that day,
As BB said, an LCB is the tool to use. But I have no idea how well it will work wired in parallel with a PWM controller. My guess is poorly.
A 12V Vmp array is good for charging a 6 or 8 V battery, Panel voltage HAS to be larger than battery voltage in order to "Push Amps" into the batteries at a reasonable rate.
Understood, should perhaps have said, 12V nominal array, just thought it unnecessary. By the way your signature says you have a 12v array, do you charge a 6v or 8v battery with that? Not serious of course.
mike95490 said:The array is NOT 12V. It is an 18V array for charging a 12V battery. Wire a pump directly to an 18V panel and you will be buying a lot of pumps. Trying to wire a 18-12V DC-DC will not work, at some point in the day (like when the PWM charger first kicks on and effectively drops the panel voltage to 12V) it will collapse the Panel voltage and no more pumping that day,
anyhow, think @nasty has come up with the best solution, run the pump from the battery.
I am starting to think running a large enough cable from my 12v distribution center 75' away to the pump might be the way to go. Need to see how big of wire it will take to minimize line loss. That way we can shower when there is no sun. Thanks for all the help.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
nasty said:I am starting to think running a large enough cable from my 12v distribution center 75' away to the pump might be the way to go. Need to see how big of wire it will take to minimize line loss. That way we can shower when there is no sun. Thanks for all the help.
Depending on your water source location and heating method, it may be cost effective to locate the pump near the batteries and run water lines to the shower.5kW grid-tied SMA + 2kW grid-tied SMA (total 4kW emergency daytime power) + 2kW genset, 500W off-grid marine system. Baja Sur. -
There are many 12V diaphragm pumps in the 8A range. Even 8 gauge is fine.
I was thinking of using 6 gauge wire. Pump is at 250 gallon water tank and pumps up 2-3' to on demand water heater.
That pump uses so little power I would get a small agm like 35-50 amps and a 80 watt panel with a ms sunguard 4.5 amp cc it would compare to the #6 price . I used a setup like that for a few years it for a few years. I doubt you will pump for more than an hour or two a day.200ah LiFePO4 24v Electrodacus Sbms40 quad breaker chest freezer to fridge- Samlex PST 1524 - Samlex pst3024 - 1hp shallow well pump-Marey 4.3 GPM on demand waterheater - mama bear Fisher wood burning stove, 30" fridgarair oven ,fridegaire dishwasher Unique 290l stainless D.C. Fridge-unique 120l portable fridge/freezer
- 231 Forum & Website
