Pv water heating
martinruss7
Registered Users Posts: 23 ✭✭
Wanting to Input a 48v battery bank(60v) into a 120v 2000 watt water heater element. Is this possible and enough power to heat 40 gal tank?
Simply connecting a load to a battery without control would be a recipe for disaster.
A diversion controller can be used to divert unused PV current once the battery is fully charged, using excess to heat water.
Without details of your system it is impossible to answer your question or suggest solutions, there are ways to do what I think you have in mind but anyone here will need details, the more the better, controller model, battery capacity, array size etc.
Might be OK if you retain the thermostat - just slower to heat up.
I looked at this some and it makes sense to me. Maybe you should consider running direct from PV.
http://www.ebay.com/itm/Solar-Water-Heater-EZ-Kit-Save-No-Pipe-Changes-Hot-Water-System-PV-MPPT-/302144306890
martinruss7 said:Wanting to Input a 48v battery bank(60v) into a 120v 2000 watt water heater element. Is this possible and enough power to heat 40 gal tank?
I'm running a 3600 watt 240 element at 120 volts on my 30 gallon water heater. It runs at 900 watts, and It takes a while to lift the temps. It's roughly 7-10 degrees per hour. With 40 gallons to heat and a 500 watt heating element you might be looking at a couple days of heating while the sun's out.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Yes I have a dump load controller that I can configure dump voltage set point
My array size is 10 72 cell 320 watt panels
In March of 2015, I sought guidance from the forum for my PV water heating system via "auxiliary load" through the controller. The thread is long, but comprehensive as many point-of-views were shared. At the end of the thread, I posted a very detailed wiring diagram in PDF form that you may find useful. My system has been operational since April 2015 and heats water effectively. The set-up cost me about $180 including relays, breakers, breaker box, wiring and electrical connection, etc. I mention this as the overall cost is something you may want to consider.
I may have an issue with where I configured the DC controller wire on the shunt, but that may only affect how the DC current is being monitored in the FNDC, not of any consequence with the water being heated. Perhaps another thread someday.
If this thread interests you, I'm not knowledgeable enough to instruct you how to get to it. Maybe someone that knows how will weighin and advise.Paul
in Georgia
System 1: PV- 410w Evergreen, Mppt- Blue Sky Solar Boost, Batt - 225ah Deka AGM, 12v led house lighting,
System 2: PV- 215w Kyocera, PWM - Morningstar PS30, Batt- 225ah Deka GC's, 12v led house lighting, Dankoff 12v water pump,
System 3: PV- 1.5kw Kyocera, Grundfos 11 SQF well pump, 3000 gal above ground water storage, dom water & irrigation,
System 4: PV- 6.1kw Kyocera, Mppt- Outback FM80-2ea, Inverter- Outback FX3648-2ea, Batt- 804ah GB traction, Grundfos BMQE booster pump 240v, Mitsibushi mini-splits 240v, 18k and 15k -
As Photowit said half the voltage equals quarter the load, in order to heat a 2000W 120V 40 gallon water heater it wold not work that we'll @ 500W, you would need in the region of 8Kw heating elements to achieve the same peformamce at the rated 120V AC, not prectical but wasted energy is energy wasted, perhaps pre warming and feeding into an instantaneous water heater could be the answer, not sure.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Anawa said:In March of 2015, I sought guidance from the forum for my PV water heating system via "auxiliary load" through the controller. The thread is long, but comprehensive as many point-of-views were shared.
http://forum.solar-electric.com/discussion/332880/series-piped-water-heaters-opportunity-load-and-propane#latest
Yep, that's it. Thanks PW.Paul
in Georgia
- 220 Forum & Website
- 128 Solar Forum News and Announcements
- 425 Caravan, Recreational Vehicle, and Marine Power Systems
- 651 Solar Water Pumping
- 608 Discussion Forums/Café
