Fans
harveybaron
harveybaron Registered Users Posts: 1
Does anyone know of a fan that is certified for 250cfm at less than 10 amps?
    What is the usage? Computer ac and dc fans use much less power but do not move much air if there is any back pressure (such as blowing through an air filter).
  • jonr
    In almost all cases, efficiency goes up with size.  Ie, large, slow moving blades.
    10 amps... AC or DC?
    Do you have a size you would like? I think the 10"O2cool would be in that neighborhood, if it's true that the Endless Breeze is 900 cfm. It draws 7-8 amps at 12 volts... I've never seen a cfm on the 02cool, but keep hearing 900 cfm for the endless breeze. Might be worth looking into.
    I've been pretty happy with my O2cool fans, have 2 running now.
  • WaterWheel
    WaterWheel Registered Users Posts: 387 ✭✭✭
    48v Rolls 6CS 27P
  • myocardia
    myocardia Solar Expert Posts: 118 ✭✭✭
    DoD= depth of discharge= amount removed from that battery   SoC= state of charge= amount remaining in that battery
    So, 0% DoD= 100% SoC, 25% DoD= 75% SoC, 50% DoD= 50% SoC, 75% DoD= 25% SoC, 100% DoD= 0% SoC
    A/C= air conditioning AC= alternating current (what comes from the outlets in your home) DC= direct current (what batteries & solar panels use)
  • dmarion
    dmarion Registered Users, Users Awaiting Email Confirmation Posts: 1
    edited July 2017 #7
    I just got a aims 4000 inverter however the fan is constantly running and will not shut off at all does anyone know why or how to stop it from running non stop appreciate any help at all.
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,137 ✭✭✭✭✭
    Cheap inverters leave a lot to be desired.
    edited July 2017 #9
    Is there a load on it?  Is it for a 12 volt battery bank? Is it in a warm area?
    Inverters for a 12 volt battery bank work harder than ones for high voltage battery bank. Also, as Littleharbor2 said, cheap inverters cut corners, it will have to have a fan, but smaller cooling area and smaller cases can be done, if it runs the fan more often.
  • mcgivor
    What does the manual say regarding fan operation, some are load dependant, some by temperature, others run at low speed constantly switching to higher speed under a certain load and the really cheap ones run full speed all the time.
    Good not cheap, cheap not good.......as the saying goes.
  • littleharbor2
    Full time fans would likely have a high, idle current draw. Not recommended to keep on continuously as it will drain your batteries.
