Newby Newb. Can you mix 12v and 24v panels into a 12v PMW charge controller?
I want to setup a 400watt solar system for my RV. All my appliances are 12v. I made the newb mistake of buying stuff first so I have two 85watt poly solar panels.... and a 12v charge controller.  Sunforce 60032 30 Amp Digital Charge Controller
I think made a mistake... I now see 12v / 24v charge controllers... auto switching.
1.Does that mean I can mix and match 12v and 24v panels ?
2. What is the biggest 12v panel out there? I found a 100 watt panel. If I found a bigger one I wouldn't have to buy a new controller.
  • oil pan 4
    The biggest "12 volt panels" I have seen were over 300 watts.
    The panel voltage going into the controller needs to be the same.
    Why do you think you need to buy another charge controller?
  • Bass-O-Matic
    Bass-O-Matic Registered Users Posts: 45 ✭✭
    Oh, only if I was going to mix and match which sounds like a non starter. Where do I buy these big panels? Thanks
  • oil pan 4
    One from here, its 285 watt and its voltage is a bit higher than normal for a "12 volt panel" but it will work very well with a real MPPT charge controller.
    http://www.solar-electric.com/solarworld-sunmodule-sw285-monocrystalline-solar-panel-33mm.html
  • Raj174
    I believe the 12v / 24v reference is battery voltage. So if you have a 12V battery bank you get 12V panels (18+ VOC) in order to charge them. Something like 4 100 watt panels in parallel would be a good example. That would charge a 160 to 230AH battery bank at 12 volts.
  • vtmaps
    18+ volts is the Vmp (not Voc) of a 12 volt panel.  --vtMaps
    Photowhit Solar Expert Posts: 6,014 ✭✭✭✭✭
    edited June 2016 #7
    Mixing might work, but only at the loss of much of the '24 volt' panels potential energy.
    I know evergreen made some 200 watt 12 volt panels, not sure what the largest is currently.
    Not sure why you think "...If I found a bigger one I wouldn't have to buy a new controller" You will be limited by the 30 amp capacity of your charge controller. You could have enough panels in parallel to reach that capacity, if they are 30 watt or 300 watt.
    The pair of these 165watt panels with your 85 watt panels would max out your charge controller.
    https://www.amazon.com/Solar-Panel-Charging-Battery-Efficiency/dp/B00G2IZ1VW/ref=sr_1_1?ie=UTF8&qid=1466769637&sr=8-1&keywords=165+watt+solar
  • Raj174
    Thanks for the correction vtmaps
  • papab
    papab Registered Users Posts: 67 ✭✭
    that's a24 v panel
  • Raj174
    edited June 2016 #10
    That's actually a 60 cell grid-tie panel, which is 30V. A standard 24V panel will have 72 cells (Vmp~36 volts).
    [fix typo. -Bill B.]
  • papab
    ?? Vmp is 31.3?
  • papab
    Sorry, I guess that is less than typical for a 24V panel.
    BB. Super Moderators, Administrators Posts: 33,658 admin
    A 60 cell silicon panel will have Vmp~30 volts (1/2 volt per cell). I think Raj174 has a typo (20 volts)--I will fix to prevent confusion.
  • Bass-O-Matic
    Thanks again! I think I'll just max out my controller and leave it at that. Dry ice is pretty amazing stuff.
  • Raj174
    Sorry Bill, I was inferring 20V nominal for 60 cells. Just as 24V is nominal for 72 cells.
  • oil pan 4
    edited June 2016 #16
    that's a24 v panel
    Typical 24 panel open current voltage is 40 up to 44 volts.
    A 30 volt panel is an ok choice for a 12v system with real MPPT controller, but its more likely intended for a grid tie setup, series 3 of them up for around 90v and you are good to go.
    It would work for a 24v system if you have a good MPPT controller.
    A good MPPT controller wont see any noticeable efficiency drop charging a 12v system with a 60 cell panel. If you used a PWM charge controller, that would be a horrible setup. With a PWM controller it would only be like 40 or 50% efficient.
    Raj, Oh, you where estimating it as a "20 volt" battery bank... A "different" way of answering the question.
