Schneider Conext 6848 with AGS to Generac 0064622
I am trying to figure out how to connect the AGS to the Generac.
Any help would be appreciated, or sources?
Off grid 48v system, 2 sets 15x255 watt panels, 2xFlexmax80 Charge Controllers, 2 sets Trojan 6v x 8 batteries, 16KW Generac with transfer switch (Grid long gone).
/d
Welcome!
  • Solar Expert Posts: 278 ✭✭✭✭
    I'm pretty sure the reason no one has answered this is because you didnt list the type of inverter  that goes with the automatic generator starter or the model of the generac
    before anyone can answer, you will need to provide those things
    12 panels 6 series 2 parallel, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
  • Registered Users Posts: 387 ✭✭✭
    He's running a Conext 6848.
    I don't use auto start but looking at the 6848 manual you need Conext part # 865-1060-01 (page 1-9) which is their generator auto start box $200 ( http://www.solar-electric.com/catalogsearch/result/?q=865-1060-01+&cat=0 ) and a breaker in the PDP to run the power through
    You may be able to directly trigger the generator through the AUX connections (Page 3-5 through 3- 7) by programming it to provide a few watts at 12v  when low battery voltage is detected.
    48v Rolls 6CS 27P
    Also needs a device (combox or SCP) to program the settings for the AGS I think .
  • Registered Users Posts: 28 ✭✭
    I am using a Xantrex AGS and a relay.  I provide power 120v from the inverter to the Generac N1-N2 leads, through the relay.  When AGS desides to run the generator (like low battery or whatever), it opens the relay so Generac thinks the power is out.  BUT, it seems like as soon as the grid goes down, the generator starts, ignoring the inverter power on N1-N2.  I am not sure why this doesn't work, but it might be in the programming of the Generac.  Any thoughts?
    On grid
    Conext XW+ 6848 Inverter SN M700xxxxx
    2x Xantrex XW 80 600 MPPT Battery Charge Regulators
    Conext COMBOX connected to the local network SN B130xxxxx
    Conext Battery Monitor
    Xantrex AGS Automatic Generator Start Control
    Generac 20KVA generator
    20x Batteries 8A4DLTP-DEKA 210Ah batteries
    24x Roof Mounted REC 255W panels
    I used this and the gen works fine
  • Registered Users, Users Awaiting Email Confirmation Posts: 1
    Which wires did you use from the Xantrex AGS and what generator type did you set in the AGS?
  • Registered Users, Users Awaiting Email Confirmation Posts: 2
    did you solve it, which cable you used? thanks
Welcome!
