Forum upgrade is complete...
Hello. I'm Mark from vBulletin Support.
I hope nobody objects, I thought it might be quickest if I popped into this thread and tried to answer any questions as best I can.
Please be aware I'm a support agent, I didn't write the software or take any of the decisions relating to it, so don't shout at me.
Ok to take the points raised so far:New Posts function missing (not the same as "Today's Posts")Missing Signature from Posts [solution known. Users can fix themselves, see post #21--Software/DB fix next week]Missing "check mark" for thread "I have posted in"
In the meantime, there is a workaround. Click your username up at the top right, and select "My Recent Posts". What this actually does is show you a list of recently updated threads that you have posted in. Not quite the same thing but it does allow you to keep track of threads you have participated in.Missing link to Northern Arizona Wind & Sun as our forum host. [Rick from NAWS is fixing]Search Window in FORUM/BLOG/etc. bar--Typing letters causes page to refresh/reloadAlso some place to include the area of the country/location?Posts in reverse order
However, as some people have spotted, you can get something similar.
Click on your username top right, from the dropdown select User Settings, then click the Account tab. Quick link: http://forum.solar-electric.com/settings/account
Scroll down to "Display Mode" and put a 'dot' in "Latest Activity". Then save.
What you'll now get is an Activity Stream view. The layout is slightly different, and you get the original post first as normal, then everything else is in "reply order", with the newest reply first.
If you try this and don't like it, reverse the process above by putting a dot next to "posts".Mark Forums Read -
On viewing the forum after the update, the first thing I noticed was that the “Topics” count is less than it was and “Posts” was at almost 201,000 and is now at 199,000. Did we lose content?
Aguarancher wrote: »On viewing the forum after the update, the first thing I noticed was that the “Topics” count is less than it was and “Posts” was at almost 201,00 and is now at 199,00. Did we lose content?
The total now excludes such things as - deleted posts (which are generally just hidden, rather than actually deleted), posts in private forums, etc. -
Thanks Mark, this new format will take some getting use to..
If you want to draw someone's attention to a post, you can now do this: [USER="11394"]Aguarancher[/USER]
It will send them a notification that you have "mentioned" them...hence this feature is called "User Mentions". -
Mark
Thanks for adressing the issues you have so far. I still have not figured out how when replying to use the Quote. I have figured out how to highlite what I quote of other people but the quotes come up with parts of the text colored. It is good enough for me but if I am missing something please let me know.
I also notice when I hit enter to put spaces between content I really can't tell where I will end up till I start typing, agian, no real bother just something I noticed.
Bill
Thanks for explaining the reasons for doing an upgrade. It makes it a bit easer to accept. Also thanks for all your help, You are one dedicated person and I hope you relize how much it is appetiated.
I am likeing the old to new setting fine now that I can hit those little arrows by the last poster and would have told you that last night but I must not have drank enough coffee cause I had to go to bed.
gww -
vBulletin Support wrote: »Hello. I'm Mark from vBulletin Support.
Thank you Mark for your help. We all appreciate you working on the issues.It's actually up there in the nav bar, it had been changed in vBulletin 5 to "New Topics" but to keep things familiar I've renamed it back to "New Posts".
Ok--New Posts/New Topics seems to be working for me--Is there anyway I can mark "Forums Read"? When we went to the new software, I now have 10 pages of unread posts/threads, instead of the 3-4 unread posts I really have (at the moment)?I've sorted this with a global query to turn display off signatures ON for everyone. If anyone doesn't want them they can turn them back off again in their settings by reversing the instructions previously posted.
Thank you.
I see location is now in the User Avatar area on the left side of the post. Thank you.
Mark, and any new people that have Registered later in the day yesterday, the Registration Conformation Email needs to be fixed... I will send a message to Mark with the details.
Thank you again for all your help Mark, and to forum members for working with Mark and Rick (from NAWS) to fix the upgrade issues.
Sincerely,
I see we have a "New Posts" button now! Hooray!!
Change is always distressing, but I am handling it.Northern NM, 624 watts PV, The Kid CC, GC-2 batteries @ 24 VDC, Outback VFX3524M -
How about a LIKE button , NO Dislike so you can add a like or take back you like !!!
Still would like the [Mark all Messages/Forums as Read] so that if I come back for 2nds or 3rds in one day, I'm not directed to all the same posts I read 4 hours ago.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
WOOHOO! New software to play with!
Ok--New Posts/New Topics seems to be working for me--Is there anyway I can mark "Forums Read"? When we went to the new software, I now have 10 pages of unread posts/threads, instead of the 3-4 unread posts I really have (at the moment)?Mark, and any new people that have Registered later in the day yesterday, the Registration Conformation Email needs to be fixed... I will send a message to Mark with the details.
Mark
vBulletin Support wrote: »Yes...on the forum index....at the bottom, just below the list of forums, and above the "What's Going On" box.
Thank you--See it there... Goto "FORUM", and scroll to the bottom and find "Mark Forums Read" in light gray text (centered below list of forums).
Just tried it... Works great!
Thank you Mark,
And I am now sending new Registration Confirmations to users that have received the original email that has missing the correct information.
Well I just gave up on a post, I had added photos from a different site, looks like the default has changed for this, use to always load to this site, now it doesn't by default, can be clicked.
after I had loaded photo from out side web site I tried to upload a photo and basically hung, it gave me no address defined(sorry not exact language)as if I had posted another url...
I'll try again an a few minutes...Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
If you wish, make the post and send me the links to what you want to post. I did get one to work OK for me today.
The second way is to use the general attachment icon on the right. It's like a piece of paper with a paperclip.
This will give you the option to insert your photos into the post, and specify a size.
Attachment not found. -
vBulletin Support wrote: »That's on the forum index....at the bottom, just below the list of forums, and above the "What's Going On" box.
It would be VERY NICE to have that appear at top or bottom, of the search results, to avoid needing to reload another page to scroll to the bottom.
It would be VERY NICE to have that appear at top or bottom, of the search results, to avoid needing to reload another page to scroll to the bottom. -
vBulletin Support wrote: »To quote a post, simply press the "Quote" link, bottom right of each post.
Very nice, got it.
I don't mean to be a bug, but, I notice on topics that have mutiple pages like this one, when you click a number it seems to do nothing and you have to hit the next/previous button to get to a differrent page. If you had five pages and you came back after reading two pages, you have to either start at the front and go page by page with the next button or start at the last and hit previous page by page. very slow and tedious if you want to check something prior in the post before commenting further.
gww -
I take that back it just worked correctly. I tried it several times before I posted my last post and it froze my computer and I closed the internet and then came back. It just worked correctly now.
Sorry for making you read my last post.
gww
Ps sorry except for the part thanking you for explaining the quote thing. -
gww
Cures a multitude of sins - if every anything odd is happening on any website, try that! -
vBulletin Support wrote: »May be worth clearing your browser cache and cookies, then restarting your browser.
I tried to quote only the first sentance but doing it twice your compleete text came up. this is not nearly as handy as picking the part you want to answer and then answering and then picking anouther part and then aswering.
On the paging thing, it happened yesterday and today and you could be correct, maby I am looking to hard on your side and need to clean up my own house.
On the quote thing, quoting a whole post is not as handy but like I said earlier, I can highlight with the other buttons
[PHP]May be worth clearing your browser cache and cookies, then restarting your browser.
[/PHP]
Like that, but when I did it last time some of the post came up in color. Even in color it is good enough and I guess we will see this time what happens when I post this.
Thank you for your help
gww -
Selecting text and quoting just the selected part has never been a default feature on vBulletin.
It's possible the site owners had an add-on that did this previously.
There's an add-on for this version of the software that will do it....it works like this:
http://www.noypiscripter.com/vbullet...quote-post.png
I can add this if the site owners would like it. -
I can add this if the site owners would like it. ]
I Would never speak for the owners and if MY above quote comes out not looking like an ad I think it is already like it was. If you push the big A on the replie, it gives a list of things you can do. The old replie box came up automatically. I would right click, copy then paste in quote marks. I think it is hear but just doesn't look the same.
I might be slow on the uptake. here goes
gww -
The above doesn't look like it used to but it is good enough for me, It does pop up a box to allow the site to have access that I have to push yes on before it works though.
gww -
That was two post with the same quoting method and the bottom one looks normal and the previous post quote looks differrent. Both Are good enough but it is weird.
gww
- 194 Solar Information links & sources, event announcements
- 890 Solar Product Reviews & Opinions
- 612 Discussion Forums/Café
- 305 In the Weeds--Member's Choice
