pex for shw systems
ws9876
Solar Expert Posts: 453 ✭✭✭
is there a PEX that is good for the water tubes in a solar hot water system??? the ones that go up to the panel and then back to the exchanger...
Re: pex for shw systems
I'm sure there is, but as temps go up, PEX pressure ability goes down. And some PEX is insulated, and you MUST be sure it's UV rated. Unprotected PEX breaks down in a couple weeks.
CPVC is better for heated water. you may need to have copper or stainless stubs coming out from the heater so you are not connecting the plastic right to the hot metal.
And depending on your system, you may need PEX with an internal oxygen barrier, since it's porous to atmospheric oxygen.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
PEX makes tubing for floor heating systems. It's for higher temperatures.
http://www.homedepot.com/p/SharkBite-1-2-in-x-1000-ft-Oxygen-Barrier-PEX-Pipe-U860O1000/202033045?N=5yc1vZbuya
Another source: http://www.pexuniverse.com/barrier-pex-tubing
I was thinking of using my leftover (Red) for a solar water heater also, but NOT for the coil in the sun, just the supply/return lines. -
I've run 1/2" PEX up to the roof of my bus to supply some quick-connect water outlets for washing my solar panels and to make feeds to and from my eventual water heating panels, and wherever it's exposed I put it inside 3/4" flexible aluminum conduit to keep the sunlight off it. You'll have to twist the conduit to spring it to a slightly larger diameter so the PEX can slide inside, but otherwise it should work just fine to protect the PEX from UV and physical damage.
John40' Crown bus with 2kW of tiltable panels on the roof:
Eight Sharp 255W, two Morningstar TS-MPPT-60, Magnum MS2000, Champion C46540 generator converted to propane, eight golfcart batteries, and maybe a small Exeltech inverter for the fridger.
Southern California
As Mike said, copper stubs are the standard way to keep the high heat of a non-circulating panel away from PEX.I am available for custom hardware/firmware development
There is a reason that the pumps are made of bronze or cast iron. The system has to survive 250F water/pressure if something goes wrong or it is unused. Use copper and your system will last and not leak. It certainly does not cost much more as most domestic solar hot water systems are less than 50 feet from the collector to the tank. Hot water can be dangerous!As Mike said, copper stubs are the standard way to keep the high heat of a non-circulating panel away from PEX."we go where power lines don't" Sierra Nevada mountain area
