pex for shw systems
ws9876
ws9876 Solar Expert Posts: 453 ✭✭✭
is there a PEX that is good for the water tubes in a solar hot water system??? the ones that go up to the panel and then back to the exchanger...
    Re: pex for shw systems
    I'm sure there is, but as temps go up, PEX pressure ability goes down. And some PEX is insulated, and you MUST be sure it's UV rated. Unprotected PEX breaks down in a couple weeks.
    CPVC is better for heated water. you may need to have copper or stainless stubs coming out from the heater so you are not connecting the plastic right to the hot metal.
    And depending on your system, you may need PEX with an internal oxygen barrier, since it's porous to atmospheric oxygen.
  • DavidOH
    DavidOH Solar Expert Posts: 112 ✭✭✭
    PEX makes tubing for floor heating systems. It's for higher temperatures.
    http://www.homedepot.com/p/SharkBite-1-2-in-x-1000-ft-Oxygen-Barrier-PEX-Pipe-U860O1000/202033045?N=5yc1vZbuya
    Another source: http://www.pexuniverse.com/barrier-pex-tubing
    I was thinking of using my leftover (Red) for a solar water heater also, but NOT for the coil in the sun, just the supply/return lines.
  • Iceni John
    Iceni John Solar Expert Posts: 103 ✭✭
    I've run 1/2" PEX up to the roof of my bus to supply some quick-connect water outlets for washing my solar panels and to make feeds to and from my eventual water heating panels, and wherever it's exposed I put it inside 3/4" flexible aluminum conduit to keep the sunlight off it. You'll have to twist the conduit to spring it to a slightly larger diameter so the PEX can slide inside, but otherwise it should work just fine to protect the PEX from UV and physical damage.
    John
    40' Crown bus with 2kW of tiltable panels on the roof:
    Eight Sharp 255W, two Morningstar TS-MPPT-60, Magnum MS2000, Champion C46540 generator converted to propane, eight golfcart batteries, and maybe a small Exeltech inverter for the fridger.
    Southern California
  • jonr
    As Mike said, copper stubs are the standard way to keep the high heat of a non-circulating panel away from PEX.
    Dave Angelini Solar Expert Posts: 7,102 ✭✭✭✭✭✭
    There is a reason that the pumps are made of bronze or cast iron. The system has to survive 250F water/pressure if something goes wrong or it is unused. Use copper and your system will last and not leak. It certainly does not cost much more as most domestic solar hot water systems are less than 50 feet from the collector to the tank. Hot water can be dangerous!
    jonr wrote: »
