Powering a 5W USB powered computer?
asteroids
asteroids Registered Users Posts: 17
I'm looking for a 12V to 5V converter that will keep going through a complete charging cycle. Suggestions? Ditto for a low power inverter, under 100W?
    Re: Powering a 5W USB powered computer?
    You may need to buy a DC-DC converter with a wide input range, and a nice clean 5VDC output. For less than 10W load, it should not be too expensive.
    here's a $45 90% eff. one http://www.digikey.com/product-detail/en/PYB15-Q24-S5-T/102-3185-ND/4477443
    just a starting point
  • zoneblue
    mike95490 wrote: »
    Any manner of ebay iphone car chargers?
    Else i use tons of these (good for 2amps):
    http://dx.com/p/mini-dc-dc-voltage-stabilizer-regulator-module-red-126106
    zoneblue wrote: »
    - Input: DC 4V-40V
    - Output: DC 1.5V-35V (adjustable)
    - Max output current: 3A
    there you are ! And the price is nice at <$5
  • asteroids
    Thanks all for the suggestions. How about a low power inverter?
    How low is low enough? 5W?
  • asteroids
    The other device is a 120V gizmo, that draws about 50W and if understand it correctly has a max draw of about 100W or so. So I'm looking for a low power inverter that I can toggle on/off or something with a low standby current.
    asteroids wrote: »
    That could be a morningstar Suresine 300 inverter. has a nifty on/off control, and very low standby/idle/inverting losses
