Powering a 5W USB powered computer?
asteroids
Registered Users Posts: 17 ✭
I'm looking for a 12V to 5V converter that will keep going through a complete charging cycle. Suggestions? Ditto for a low power inverter, under 100W?
Re: Powering a 5W USB powered computer?
You may need to buy a DC-DC converter with a wide input range, and a nice clean 5VDC output. For less than 10W load, it should not be too expensive.
here's a $45 90% eff. one http://www.digikey.com/product-detail/en/PYB15-Q24-S5-T/102-3185-ND/4477443
just a starting pointPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: Powering a 5W USB powered computer?You may need to buy a DC-DC converter with a wide input range, and a nice clean 5VDC output. For less than 10W load, it should not be too expensive.
Any manner of ebay iphone car chargers?
Else i use tons of these (good for 2amps):
http://dx.com/p/mini-dc-dc-voltage-stabilizer-regulator-module-red-1261061.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
Re: Powering a 5W USB powered computer?Any manner of ebay iphone car chargers?
- Input: DC 4V-40V
- Output: DC 1.5V-35V (adjustable)
- Max output current: 3A
there you are ! And the price is nice at <$5Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks all for the suggestions. How about a low power inverter? -
How low is low enough? 5W?
The other device is a 120V gizmo, that draws about 50W and if understand it correctly has a max draw of about 100W or so. So I'm looking for a low power inverter that I can toggle on/off or something with a low standby current. -
Re: Powering a 5W USB powered computer?The other device is a 120V gizmo, that draws about 50W and if understand it correctly has a max draw of about 100W or so. So I'm looking for a low power inverter that I can toggle on/off or something with a low standby current.
That could be a morningstar Suresine 300 inverter. has a nifty on/off control, and very low standby/idle/inverting lossesPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
