Robin RGD3300 Diesel Genset
ChrisOlson
Banned Posts: 1,807 ✭✭
This is my "new" Robin diesel generator. Bought it for $775 off craigslist. I think it's a 1999 model. Direct injection with no glow plug, electric start, brushless generator. She puts out nice stable power and will put out slightly over 4 kVA on surge for 20 seconds. Ran it at full rated load (3.05 kVA) for one hour and it burned 795cc (.21 gallons) of #2 fuel - figures out to just about 30% efficient. Not too bad for a little unit.
When I called the guy yesterday he told me it has a Hatz diesel on it. I looked on the internet and the new ones do use a Hatz 1B30 diesel. When I saw it the first time and seen that it has a Robin DY27-2D on it I tried not to smile too much when I handed him his money.
Chris
Chris
Re: Robin RGD3300 Diesel Genset
Chris, I keep getting an error when I try to open the attachments???
I could open the attachments OK...
But, I opened and then re-saved the post just in case.
See how it works now.
Re: Robin RGD3300 Diesel Gensetwestbranch wrote: »Chris, I keep getting an error when I try to open the attachments???
Sorry - I must've done something bad when I posted it. I went to the Advanced and re-attached them so they should show up (maybe).
[video=youtube_share;WlXlqTwxgHs]http://youtu.be/WlXlqTwxgHs[/video]
Chris -
got them now... what sweet little machine, and elec. start to boot! were you wearing a black mask at the time?
Chris,
You ad worse than me' collecting bargains, thing is, all I got is antique junk, you keep finding cool newer stuff!
Tony -
Good generator and a good buy Chris. I have the 5kw sized unit with a Hatz engine on it, and they are loud. One thing I noticed on it was the voltage regulation is not an electronic type but condenser (I think this is what was described to me). It's great for heavy lugging loads like a compressor or something, but apparently not so good for electronics and such. If you have access to an oscilloscope a look at the waveform would tell you how clean it is compared to some of your other generators. Mine was backup to the backup, so never got anything but exercise done to it. Can't sell it, everyone thinks it's worth $1500 tops, paid $5k for it 4 years ago (someone must have pressed on the soft spot on my head, made me buy it).
A start below or close to freezing temperature and it will snort, bang and blow lots of smoke. Sounds like the piston will come flying out, but still goes. Trying to hand start is futile for anyone not in shape with shoulders like the Hulk...or a farmer.
Ralph -
I've been looking for either a used Yanmar or a Subaru-Robin for awhile because I wanted it for prime power. If I want to have "grid" power for long periods of time on the AC1 input of our inverter the little Robin will do it cheap. I couldn't believe the fellow sold it for only $775 but it worked out because he needed more money and less generators and I needed more generators and less money.
Ralph - the Robin engine has a Zexel injection pump and nozzle so it starts and idles quite nicely when it's cold. Under normal operation that's what I'll do - start it and let it idle at 2,000 rpm for a few minutes to get warmed up. It also has a smoke screw with a governor buffer to increase the torque rise and power output under surge (which I already tweaked). She blows pitch black smoke now when you try to lug it down and it won't lug down under surge load. It would only put out about 3,300-3,400 VA when I first ran it on surge. But I got that up to 4,000 VA for 20 seconds before the breaker trips - although the cloud of black smoke is pretty impressive after I tweaked the smoke screw.
Chris -
More playing with the Robin generator. I pulled the injector, tore it down and set the opening pressure (it was a little low) and ran a 3-4 hour load test on it. With gen (actually grid) support on AC1 it handles our clothes dryer, electric range, and just about anything else you want to throw at it. It's got considerably more stable output than our Champion generator does, especially in surge. The diesel has 2x the torque of the Champion gas engine. And brushless self-exciting generators are a weird duck in surge because the flux in the exciter winding actually increases under load, causing voltage to the field to rise under load instead of drop like an AVR gen head does. So it has the result of no voltage drop under surge load, and only a drop of about 1-2 Hz during overload.
Pretty impressive little generator, overall.
[video=youtube_share;4dRRGE5Py1A]http://youtu.be/4dRRGE5Py1A[/video]
Chris -
can it auto start, and can autostart allow a warmup before hitting the power outlets ?
And how does it manage unbalanced loading, windings growl, or does the autotransformer balance it for you?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
There are two of those in my neighborhood, great, reliable power. Survived 3 Hurricanes and easy to find diesel when all the gasoline was gone. -
Yes, it can easily be set up for autostart. The controller takes care of the warmup period before loading it.
It can handle up to 12.5 amps per leg so it wouldn't make it very far on a split-phase system with high loads without the transformer and the XW to help it out when it needs help.
Chris -
Re: Robin RGD3300 Diesel Gensettonystewart wrote: »There are two of those in my neighborhood, great, reliable power. Survived 3 Hurricanes and easy to find diesel when all the gasoline was gone.
Yep. I'm going to build a generator room on my shop and heat the generator room in the winter. When we get bad RE power days, and when I'm working in the shop using a lot of power, I'll just start it and leave it run. It can't run my shop by itself, but feeding the AC1 input on the inverter it can.
A lot of off-grid folks are afraid to run generators, like it's a sin or something. But they got 8 or 12 (or some bigger yet) kW generators that suck whole oil fields dry, and they only got half the loads we got. Never been able to figure that out. And that's why I've been looking for one of these for awhile (or a Yanmar YDG3600). It's matched to the loads to provide supplemental power when needed, I can start it and leave it run for two days, and still can't burn up a 5 gallon of fuel. It runs cheaper than a Honda EU2000 and has >1.5x the power.
Chris -
Re: Robin RGD3300 Diesel GensetChrisOlson wrote: »It runs cheaper than a Honda EU2000 and has >1.5x the power.SMA SB 3000, old BP panels.
Re: Robin RGD3300 Diesel GensetBut it sounds like a diesel! In your movie it actually seemed louder while warming up at fast idle than once you got a load on it.
That's because it's got a centrifugal advance on the camshaft that advances the injection timing above 2,800 rpm. At low idle it's running at full retard (which is done for easier starting), so it makes a lot of noise and smokes a little bit.
Chris -
Re: Robin RGD3300 Diesel GensetChrisOlson wrote: »That's because it's got a centrifugal advance on the camshaft that advances the injection timing above 2,800 rpm. At low idle it's running at full retard (which is done for easier starting), so it makes a lot of noise and smokes a little bit.
ChrisSMA SB 3000, old BP panels. -
Soundproofing a must as well. A diesel banging away would drive most of us batty. Wait! I just remembered your wood chipper video...forget this post.
Ralph -
Re: Robin RGD3300 Diesel GensetSoundproofing a must as well. A diesel banging away would drive most of us batty. Wait! I just remembered your wood chipper video...forget this post.
Well, the 12V71 on the chipper runs out in the middle of the woods where it only bothers a couple squirrels. I'll build a sound attenuated generator room for the little diesel and put a truck muffler on it. It will be as quiet as the Honda. I got a little Schweitzer turbocharger around here someplace that came off a Honda CX500 motorcycle and I might rig that up on it. The Robin DY27 has a pressure lube system and I can tap off the oil sender for oil to the turbo. That would even make it meet Tier IV. That's the only reason they don't sell the DY23/DY27 in North America anymore - they wouldn't certify for emission standards. They still sell them in every other country (except EU countries) but they discontinued sales in the US and Canada in 2005 and switched to the Hatz 1B30 on the post-2005 Subaru-Robin RGD3300 gensets.
Subaru then switched their attention to their new gas engine line that has chain-driven overhead camshafts.
The Robin is a much tougher and more durable engine than the Hatz and it has Zexel injection instead of Robert Bosch. The injection pump on the Hatz diesels has been very problematic. The Zexel pump on the Robin was designed and built thru a joint effort between Diesel Kiki and Zexel, and are bullet-proof, mainly due to superior quality control and machining by the Japanese.
Chris -
The latest modification. I got the little Robin DY27 tweaked for peak torque rise. I set the Gen Support amps to 140% of the prime power rating of the generator so the XW will load it and unload it to tweak the smoke screw for best torque rise. I got it so it will go to 3.5 kVA for 20 seconds and only drop one Hz. Can't do that too long, though, because it will pop the breaker on the genset. Setting Gen Support up to 150% overloads it to 4.0 kVA and then it pops the breaker. But it still holds with only 2 Hz drop at 4.0 kVA (before the breaker trips).
[video=youtube_share;uEIb3E2-kyw]http://youtu.be/uEIb3E2-kyw[/video]
Chris -
Our Robin powered Makita G2800L has proven to be a great piece of equipment. Easy on gas to.
ThomOff grid since 1984. 430w of panel, 300w suresine , 4 gc batteries 12v system, Rogue mpt3024 charge controller , air breeze windmill, Mikita 2400w generator . Added 2@ 100w panel with a midnight brat -
I've heard that the chain-drive overhead cam Subaru-Robin small engines are pretty formidable units. The DY23/27 diesels are well designed also. They have a full pressure lube system with bearing inserts on the big end of the rod instead of just running it aluminum on steel. They have a die-cast aluminum alloy head with cast iron valve seats and sodium filled stellite valves. They have forged piston and rod with chrome-faced compression rings on the piston. Forged steel crank. Timing retard/advance with a decompressor for easier starting.
I adjusted the valves on it a couple days ago and even the valve train is well designed with cast iron rockers on a shaft instead of ball and stud type rockers like many small engines use these day.
Chris -
Been mulling over the best way to use the little Robin diesel for prime power when the RE system don't work. I've pretty much decided to build a new powerhouse with both generators in it and make it big enough so a person can stand up in it and have room to service the generators without moving them or unhooking them from their exhaust systems, service wiring and control wiring. I'll leave the Honda EM4000 on auto-start for peak loads hooked to AC2. And I'll have the little Robin on manual start hooked to AC1. I'll probably build the powerhouse with a walk-thru insulated steel door so a generator can be wheeled in or out.
The Champion is on wheels so rather than permanently wiring that into a transfer switch for backup on AC2 I'll leave it as portable power so it can be used where ever it is necessary.
I did have a little problem with my Guaranteed To Look Like Real Chrome Paint on the exhaust stack on the Robin. It sort of burst right into flames and burnt off during load testing. So I went with 1000 degree BBQ Power Black (at least that's what it says on the can) instead
The stack is 1.5" OD and 1.5" ID flex pipe fits nicely over it so the exhaust can now be easily plumbed in a large truck muffler to make it really quiet. Plus I welded on some stack braces so the stack don't bust the outlet on the muffler eventually.
The fuel tank holds three gallons of fuel. I test ran it a couple days during an extended rainy period here when we didn't get hardly any RE power - running on AC1 for prime power like I plan to use it. It runs at varying loads anywhere from about 800w -1 kw to full rated power (3 kW) doing that. The batteries stayed pretty much at float voltage the whole time and it ran for 14 hours during the test. I refilled the tank from a 2 gallon can and it could've held a little more fuel yet, but not much. So it runs pretty cheap and the batteries were pretty happy because they basically went on vacation during the run test. The little prime power generator can prevent cycling the batteries during bad RE times. So my thinking is, what's cheaper? A few gallons of diesel fuel for bad RE times, or putting some more cycles on the batteries and sometimes having to charge them with the Honda because they get below 50% SOC? Batteries are $9,000 for new ones - I can buy a LOT of diesel fuel for $9,000.
This generator would not be suitable for auto-start and peak load. It requires a five minute warmup at fast idle before you put it to work, or it's hard on it because it over-fuels due to incomplete combustion. And it's going to require substantial pre-heat to start it in the winter (haven't figured out what to do for that yet). But once started, warmed up, and online - it runs so cheap that it's almost unbelievable. It is one of the smallest 120/240V diesel generator sets that you can buy, so it's sized perfect for the type of duty I'm going to use it for.
I've tested it plenty now, and it performs flawless. Just need to finish figuring out the details of how to integrate it so it works the way I want it to - all in the hopes that it will eventually pay off in battery costs.
Chris -
Re: Robin RGD3300 Diesel GensetChrisOlson wrote: »and switched to the Hatz 1B30 on the post-2005 Subaru-Robin RGD3300 gensets.
It is also not clear whether the current model is rated for prime mover use. Part number is now RDG3300H, for Hatz, I guess.SMA SB 3000, old BP panels. -
Re: Robin RGD3300 Diesel GensetSounds like you are lucky to get the old one. The first review I found online for the current model using the Hatz stated that cost for a replacement (plastic) fuel tank was $500 plus shipping from Germany. :-(
Yes, the H-suffix model comes with a Hatz. The models with the Robin DY27 are still sold overseas (except in some EU countries) where they don't have to meet stringent emission specs. They stopped importing them here in 2004 due to emissions (Nox is off the scale on the little Robin due to extremely high exhaust temps and the high compression ratio).
The Hatz diesels have had their share of problems with injection pumps too. I had one given to me because it wouldn't start due to a bad injection pump, and that seems to be a common theme with them - they run while they run and when they break they're so incredibly expensive to fix that they get junked.
Chris -
Our old Honda generator tank rusted out at 10 years or so . I just used a old motorcycle gas tank . Welded on a snowmobile muffler when it went . Honda parts are expensive !
Re: Robin RGD3300 Diesel GensetHonda parts are expensive !
Oh, Honda is VERY proud of even a quart of GN4 oil
Chris -
I got the new power house for the generators partially framed up today. I'm putting a 36" insulated steel walk-thru door in it. It's 6 feet square. It'll be a white steel building with green trim to match the other buildings. 6" insulated walls and ceiling and a floating 3/4" treated plywood floor. It'll have cross-flow forced air ventilation.
Chris -
A little more progress. I got the new powerhouse partially sheeted in with a roof on it. The Robin diesel will be against the back wall as you come in the door with the switch and control panel facing out, and the exhaust routed out overhead. The Honda EM4000 will be to the left of the door with the switch and control panel facing out and the exhaust routed directly out the side like it is in its present small enclosure.
I bought a pre-hung insulated steel entry door and that door will stay locked all the time. That is necessary to keep the grandkids out of there because if they go in there and see switches and buttons they'll flip and press them just to see what happens.
Chris -
For noise Chris, what insulation will be in the gen house? In mine I just used fibreglass batts, then builder's lath (like chicken wire) screwed up over the insulation. This way the shed is insulated but the insulation can absorb the sound energy, it's not bouncing back and forth against plywood, chipboard or the like. Before the shed went up the gen sat under an open shed steel roof and the din while running was unbelievable! Painful to be within 10 feet of it, but inside it's little insulated house you can be in there to check things out without even earplugs.
Sounds like you got quite a find in your little Subaru.
Ralph -
I bought a 39 foot roll of 6" thick x 24" wide fiberglass insulation. And I figured I'd cover that with that fire-retardant foil-faced 1" foam stuff like I used in the small enclosure for the Honda. For ventilation I'll pressurize the building like I do with the present small enclosure, as that helps force exhaust gases (where the most heat is) and fumes out the exhaust vents.
With the building well insulated and louvers that close on the ventilation fan intake and exhaust vents I'm hoping I can keep it above freezing in there in the winter with the same 75 watt heat lamp that I used to heat the Honda last winter. At least that's my hope - time will tell if that's going to work or not.
Chris -
Beware that mice LOVE nesting in fiberglass! If it is open on one side and you live in any mouse country, do your damnedest to seal the building, and patrol with traps, or the batts will be riddled with mouse warrens!
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
